Question about LG VOYAGER VX10000 Cellular Phone
Huawei phonebook bluetooth
My huawei phone phonebook will shows to be empty after it updates
Huawei G3512 bluetooth (optional)
According to the specs, the device you're talking about has bluetooth. May be the software in your device is not up to date. That may be the reason to show it as "optional". But I'm afraid I don't think you could update the device firmware. May be a phone repair center could do it.
Jun 16, 2017 | Huawei G3512 dual sim unlocked gsm phone
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
How to export phonebook to pc? How to export
Re: Export phonebook to PC:
hi, you can transfer your contact details through your pc, by first u may use phone usb, then connect your phone usb to computer and go to my computer, chech for removable disk and find their your phone motorola RAZR V3, open it, go to phonebook and you may copy your phone contacts by simply clicking right click,choose copy and you may save it to your documents.
RE: Transferring phonebook to another mobile phone?
you can do that by first activating your bluetooth under connectivity. once activated/on go ack to phonebook, click send via bluetooth.
Nov 18, 2010 | Motorola Mobility RAZR V3
Good afternoon, I have a Parrot CK3200, and a 3G Iphone, and am completely unable to sychronise my contacts to the Parrot. The devices pair perfectly well and, when a call is made from the phone, the...
If you have had the parrot a long time you will need a software update, this can be done from a laptop with a bluetooth dongle. Try Parrot.com/support you can also try sending the contacts via bluetooth to the parrot one by one.
Feb 07, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
SGH-u700 - Ford Sync - Bluetooth - downloading phonebook
contact your samsung mobile store and have them upgrade the sync for you to pair with the car.
May 30, 2009 | Samsung SGH-U700 Cellular Phone
Need to add and delite numbers to phonebook
I can help you with the phone numbers on your Garmin Nuvi 265WT.
Follow these three steps to take to get your Nuvi 265WT running like new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Erase Nuvi 265WT Phone Numbers here.
Nuvi 265WT Manuals here.
May 18, 2009 | Garmin nuvi 265 Car GPS Receiver
I was having the same problem.. I had to get a new phone in order to download the phonebook. I got a samsung A827 andit took care of the problem. I had to go to the phone store and trial and error phones until I found one that worked. The list on Syncmyride.com contains many older phones that the stores don't carry anymore. Good Luck!
Apr 30, 2009 | Samsung SGH-U700 Cellular Phone
Garmin 265wt. How do you delete duplicate # fm phonebook?
I hope that helps.
Feb 10, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmin zumo 550 bluetooth pairnig problem
Have you connected the device to the computer and run webupdater? Mine showed up with a bluetooth firmware upgrade. Bluetooth works fine, however, lost the functionality of the phonebook after the update. Sometimes you win sometimes you loose
Mar 28, 2008 | Garmin zumo 550 GPS Receiver
Bluetooth transfer of phone book?
I got a solution:
Used hardware:
Pioneer DEH-P65BT
Jailbroken!! Iphone 3g FW: 3.1.2.
Mac or PC (addressbook on Mac or Outlook on Win)
Steps:
- Sync your contacts trough Itunes with your PC or Mac
- Go to addressbook on Mac (or Outlook on win) and export all your contacts to a vcf file (Called Vcards in addressbook)
- Copy the vcf file to your Iphone (iphoneExplorer / SSH / DiskAid or other solution)
- Download iBluetooth (I used it from the Xsellize source)
- Set up you radio to PhoneBook Transfer (Your phone is not connected to the radio at this point)
- In iBluetooth browse to the VCards.vcf and send it to the Pioneer unit.
- It now says transfer done and the phonebook is stored.
Posted this because it took me days to get it working. Haven't found a working solution on the net.
Also transfering the phonebook from another phone isn't a solution because however the phonebook will be stored it won't be usable by your iphone. The pioneer registers the phonebook to a device so it's absolutely necesarry to transfer it from the actual iphone (or send it from a laptop with a spoofed BT-Mac that matches your iphone)
- Cedrick
Jan 21, 2008 | Pioneer AVIC-D3 Car DVD Player
LG VOYAGER VX10000 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
