Question about Pride Sonic 3 Wheel Portable Scooter
Quingo plus model does not go and flashes 7 times
Quingo plus model will not go and the green light is flashing 7 times
Quingo air wont go. New batteries showing charged but green light still flashing. Have checked not in free wheel
How many times does the light flash. This will tell you the fault. Then check in the trouble shooting guide in your manual.
Apr 18, 2015 | Health & Beauty
I have a quingo plus mobility scooter when I've switched it on the green led flashing always 5 times. What fault that mean? Just fitted new batteries.
hi, that is related to your brake, either a wiring issue, connection etc, the micro-switch located on the brake or the brake resistance changing ..
Regards
Rob
www.gewizrepairs.co.uk
Mar 26, 2015 | Health & Beauty
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Canon PIXMA iP1000 Printer - don't work
GO ON LINE
CANON PIXMA iP1000 7 FLASHING LIGHTS
ENTER
ROD
Feb 04, 2009 | Canon Office Equipment & Supplies
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Pride Sonic 3 Wheel Portable Scooter  Logo
74 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
