Question about Music
A400122 What date was this guitar manfactured
I have a egmond guitar, serial number 71122269. Can somebody advise what year this was made and where?
It was made in Eindhoven Holland. Egmond produced large quantities of guitars with models from cheap to quite good, for that time.
The serial number does not date the guitar, you have to look for other clues, as here
http://web.archive.org/web/20120511064338/http://www.egmondguitars.nl/dating.html
Jan 10, 2017 | Music
B.C. Rich Ironbird Pro guitar serial no G01111219. What year was it made and where?
Dating Your Rich Guitar Dolphin Music
The relevant part -
In November of 2000 B.C. Rich implemented a new date stamp format for serial number coding of it's imported models. . This started on the January 2001 models. All B.C. Rich models, both imported and usa handmades implement this same year time date stamp and guitar production number format:
121XXXXX first digit = year of manufacture
second digit = means nothing until double-digit years get here again
third digit = quarter of manufacture
digits 4 thru 8 = production number
Current US-made B.C. Rich serial numbers follow the same year and guitar production number format. (example - serial number #24123 was the 123rd guitar made in 2004)
Jun 10, 2016 | B.C. Rich Music
I have a vintage guitar made by Conn with serial number 79-0908, model C74 I need a manufactors date
Getting date information on lesser known instrument brands (Conn horns are one thing, guitars are another) can be difficult. in this case, Conn wouldn't have made the guitar, but would have sourced it from a offshore maker. I suspect it would be made by Samick. Generally, the first two numbers are the year on Samick products, so probably 1979.
Mar 01, 2015 | Conn Music
I am trying to date My moms Goya guitar with serial number 371741
Hello
The serial can place the year at 2 different years....either a 1958 or a 1967. Goya has a long history or being bought by different companies and they all had a different way of serial numbers. But there is a way to tell the difference. Check this site out as it is very informative and will help you date this guitar. http://www.vintage-guitars.se/Levin/Goya_serial_numbers.htm
Also, jsut for the hisstory side of things check out this site. Vintage Goya Guitars
Feb 26, 2015 | Music
What is the date for my Goya guitar serial number 371741
Hello
Also, jsut for the hisstory side of things check out this site. Vintage Goya Guitars http://www.vintage-guitars.se/Levin/Goya_serial_numbers.htm
Can i find out the age of my eko guitar from the serial number
Unfortunatly, once you get past the well known Fender/Gibson/Gretch brands, info gets harder to come by.o can try contacting Eko directly in Italy. Here's a link
Numark Marshall Dunlop Korg PRS Akai Sonor EkoMusicGroup distributore di...
Or you can date the guitar off the codes on the pots. Here's some info on that-
Vintage Guitars Info dating vintage guitars amps by date source code
Feb 21, 2015 | Music
How do I look up a Fender guitar serial number for a electric guitar?
Google search fender product dating.
This should help.
Nov 12, 2014 | Fender Music
Where is V193037
Guitar Info This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 12, 2014 | Fender Starcaster Strat Electric Guitar -...
Guitar date of manafacture
What you have listed is an invalid serial number. If you go to:
http://www.yamaha.com/apps/guitararchives/guitarserial.htm
you can type in the serial number and get your answer.
Jun 06, 2010 | Yamaha Electric Guitar
Music Logo
14 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
