Question about Therapure Four Person Inflatable Round Hot Tub
Wont heat up
The heater wont heat up
  • 2,760 Answers
Other than the heater having a fault inside of it (common problem) the only thing that a user can do is to make sure it was proper power connection (outlet is live) and make sure it has good flow thru the heater , as they do have a flow switch that prevents heater from coming on if water flow isn't enough(safety sensor)
Posted on Jun 08, 2015
Front heater not blowing any heat
You will need to be more specific ... front heater wont turn on after using the on switch? Heater blows but only warm air ... heater blows cold air .... see what I mean.
Nov 26, 2013 | 2008 Hyundai Veracruz
Heater wont heat up
Check your engine running temperature. If not up to temp, then replace thermostat.
If getting up to temperature, then check operation of the heater matrix valve, cable/motor and switch assembly.
Nov 13, 2012 | Chevrolet Cars & Trucks
Heater wont heat it says 106 all the time
The thermistor is bad...its job is to read the temperature of the water and transmit it back to the control board. Your replacement part number is 42001-0053S.
John
Apr 22, 2011 | Sta Rite StaRite 400000 BTU Heavy Duty...
2000 Silhouette: HEATER WONT GIVE OFF HEAT THEIR IS HEAT BUT WONT S...
Check the water level. If the water is low it will not allow water into the heater core to produce heat. If there is water keep an eye on your temperature gauge It should reach at least 140 to 170 degrees. If it is staying colder than that you have a stuck thermostat which is allowing the water to flow to much and not let the engine warm up. The only other solution is if the fan is not working properly replace the fan relay for you blower.
May 17, 2010 | 2000 Oldsmobile Silhouette
WONT HEAT. BLOWER COMES ON BUT NO HEAT. IT HAS NO
I'm assuming that this is a portable heater. If not let me know. If it is it sounds like the heating coil is bad or the relay which turns on the heat is not working. TU probably means turn up the thermostat. I guess you could try that but it seems pretty obvious. Let me know how you make out.
hardrocko
Feb 10, 2010 | Honeywell Programmable Thermostat Heater
Heater wont run on hi and doesn't get warm at all
One of two things here. You blew an internal fuse or the heating element is broken. Take your unit apart and check for bad fuses and also check that the heating coil has continuity. Let me know how you make out.
hardrocko
Feb 07, 2010 | Holmes Products HFH5606-U Compact Heater
The heater only blows lukewarm air.. can u help
make sure you have a thermostat.because if not you wont have no heat also heater core stopped up you wont have heat
Dec 10, 2009 | 1998 Ford Taurus
The heater wont blow heat but the a/c works. Any
coolant level up to the top ??heater pipes havent been blocked off ??
Nov 07, 2009 | 2001 Kia Sephia
Water heater doesnt heat up
has the unit every been cleand you can check the it in the service door
Dec 01, 2008 | Water Heaters
Therapure Four Person Inflatable Round Hot Tub Logo
391 people viewed this question
Top Therapure Pool & Spa Experts
The Cover Guy
The Cover Guy
Tom Chichester
J.D. Browning
J.D. Browning
Are you a Therapure Pool and Spa Expert? Answer questions, earn points and help others
