Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker not filling with water
The refrigerator is a 22cu. ft. sears kenmore coldspot model # 106 9542882.
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    do you have a water dispenser?
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 12 Answers
SOURCE: Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Posted on Dec 01, 2008
freetek
  • 5568 Answers
SOURCE: amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Posted on Jan 09, 2009
  • 5 Answers
SOURCE: Whirlpool refrigerator will not make ice
This is almost always due to a faulty shutoff valve. The valve is at the back, where the water line connects to the refrigerator. Turn off the water supply, remove the water line with a wrench. You should be able to take out the valve with a few screws and by removing one or two wiring clips and the plastic line on the other side leading to the fridge. A new one costs about $60 - $80 at a appliance parts store. Bring the old one with you, and the refrig. model number, and make sure the new one looks the same as the old.
The problem stems from the valve continuing to leak a bit of water to the icemaker after it fills the tray and shuts off. This trickle of water freezes and blocks the line, so matter how many times you defrost it, it will just happen again.
Posted on Jan 14, 2009
aborcass
  • 2651 Answers
SOURCE: Kenmore Coldspot Ice Maker Gear Broken
best bet os to order and replace the entire assy, the gear broke due to an over torquing problem that they fix with a kit that ioncludes a new module and a new stripper bar, the labor involved and chance of breakin more parts make the entire assy a more feasable way to go, you can proble find a repacemnt online for undder $75
Posted on Feb 16, 2009
Kenmore coldspot model 105-56532400 ice maker leaking water. How to fix?
The water supply solenoid valve may be malfunctioning or the fill tube to the icemaker may be mis-positioned.
Mar 01, 2015 | Kenmore Refrigerators
I have a Kenmore Coldspot Side by side refrigerator model 58787892. The ice maker is not making ice. The mechanics of the maker work but it does not fill up with water. The filter is changed regularly...
check to see if the ice tube going into the ice maker is frozen up. you may have to thaw it out to get water to reach the ice maker again. lmk if that's not it
Aug 05, 2013 | Refrigerators
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
Sep 02, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Ice maker pump
that sounds like a company thats not willing to back there work if you ask me. Im to assume that there ws no ice before replacing the ice maker correct. and if thats the case , then perhaps the water valve was bad all along and you didnt need a ice maker.
Mar 30, 2008 | Refrigerators
Ice maker won't make ice
The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
