Question about ViewSonic N3000W 30 in. HD-Ready LCD Television
DVI-HDMI work but there is no sound
Hello, I have this N3000w connected to a Freeview box which has a HDMI port and I have the cable but since the TV doesn't have this socket I have bought a DVI/HDMI connector. When I choose the DVI input (no HDMI input available on menu) the image is great but there is an empty sound coming from the TV. If I choose a different input such as scart, both image and sound work, so I know there is no problem with the speakers...can you please suggest something so that I can get the best of the picture with the DVI/HDMI connectors AND hear something??? Thanks a million..
M.
    Master:
  • 507 Answers
DVI input has no sound as normal you can use a RCA connection to get sound from the freeview box
Posted on Apr 22, 2017
JSPCEXPRESS
  • 178 Answers
SOURCE: HD DVI HDMI problems.
As long as the phono socket is red or white. That represents Audio
Posted on Feb 13, 2008
SOURCE: Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Posted on Mar 18, 2008
kevin000
  • 1847 Answers
SOURCE: Viewsonic VPW425 No inputs working
Seem like the power supply hav blow off inside the unit.
Posted on Jul 02, 2008
  • 6 Answers
SOURCE: ViewsSonic n3000w sound working, but picture is not
Your inverter is bad. i think there's 8 transformers.. one for each backlight.. one of them is sorted and is bad.. if you know something about electrics you can try to find one transformer or you can try to find the whole inverter.. good place for parts is http://www.lcdparts.net
Posted on Oct 30, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Trying to hook up my PS3 to my Viewsonic N3000W to
Your TV has a DVI input connector, but no HDMI as you noted. Adapters (fondly called "dongles") are available to convert from the DVI connector to an HDMI jack so you can connect your HDMI source. Search for "dvi to hdmi adapter" with your favorite search engine and you will find them.
As for settings, this set has 720p resolution. Make sure your source is set accordingly, and you should be set to get the best quality you can with the connections available.
Please take a moment to give this solution a fixya rating if you've found it what you needed, and thanks for asking here!
Posted on Mar 05, 2009
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
It seems has if the HDMI port on my Scenium is going bad. For quite a while, it would occasionally turn people's skin blue. Pulling out the HDMI cable and reinserting it would usually correct the...
hi,
Your TV didn't have any HDMI port. Do you mean the DVI port. do you use DVI cable or DVI to HDMI cable.
The only way to check whether the DVI port is working or not is by replacing the cable. purchase a new cable and try again.
ok
Jan 31, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
How do you connect the Virgin VHD box to LG RZ32LZ55 TV for getting HD and also the audio. For the audio the V HD box has a optical audio port and a test port ( i am not sure it works!). The TV has a DVI...
All you need is an hdmi-dvi adapter. You will also need a component audio lead to plug into the mini(3.5) jack socket on the tv as dvi does not carry sound. You will need to initially use the scart to set up your tv for hdmi as the menu can only be seen via the scart until you set it up.
Jul 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Trying to hook up my PS3 to my Viewsonic N3000W to enable me to watch HD BluRay Discs. There is no HDMI socket at the rear of the telly. Disc plays but HD picture quality looks the same as ordinary DVD....
Mar 05, 2009 | ViewSonic N3000W 30 in. HD-Ready LCD...
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
HDMI Connection
to narrow it down get the right cable and do your connection.if it does not work have the cable company take a look at your cable box.if that dont work then you can safetly say it is your tv.then it will be time to call in the repairman.
Mar 30, 2007 | NEC PlasmaSync PX-61XM2A 61 in. HDTV-Ready...
ViewSonic N3000W 30 in. HD-Ready LCD Television Logo
161 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
