Question about Canon FS100 Flash Media Camcorder
Muting the mic
Need to mute the mic during recording
Plug in a 3.5mm stereo "pin" plug, into the external microphone input. This will open the internal microphone circuitry and allow for silent recording.
Posted on May 25, 2014
How to unmute my Samson Meteor Mic?
There are 2 ways to mute or un-mute the mic:
  1. Push the button on the front of the mic
  2. On the computer, open Recording Properties and go to the Levels tab and click the speaker icon next to Microphone slider.
Jul 06, 2014 | Samson Audio Players & Recorders
Well, how do I get the producer usb mic to be mute while in playback???
If you disarm recording on the mic it should mute during playback. Just click the record button again to disarm it. Good Luck, Cody J.
Dec 17, 2010 | M-Audio Producer USB Microphone with...
My mic seems to pick up internal noise even when muted
Hi, You can check you the connectios or the mic. remember that the mic is too sensitive, you can adjust it with the nobb on the mic by putting it on o -dB and reduce the highs on your mixer or EQ to reduce hiss sound.
But fisr check the connection properly to see if when muted, is muted properly.
Take care.
Jun 08, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Microphone doesn't work on Logitech ClearChat Premium PC headset. I've checked jacks, mute switch. Ran Paretologic to install proper drivers. Is there an on and off switch for the microphone (not the...
If the mic mute switch is not on and there is no red light in the mic arm then its likely you have a check in the 'mute mic' box in your sound manager. Open Volume control, choose options->properties-> recording. Check for checks in the boxes and remove them. Also make sure the slider for the mic is about half way up.
Mar 19, 2010 | Logitech (980240-0403) Microphone
How to configure a headset with mic?
Headset will have two pins .plug the pin initially
The green pin should be plugged to speaker and the red pin to the mic.
In the volume button select the advance properties and increase the volume of mic .sometimes it may be in mute if so un mute it.
Ensure proper drivers are installed and mic is detected i the system.This can be seen from the sound devices option in control panel .
To check whether mic is working try to record using the sound recorder which is present in system
Mar 04, 2010 | Computers & Internet
I can hear other people but when i speak they cant hear me
The problem is with the mic you can verify it with by trying to record the sound using the sound recorder application. if you not able to record the sound.check whether mic is detected and it is not muted .sometimes mic may be muted.increase the volume of the mic by clicking the sound control option.
Mar 03, 2010 | Apevia Laptop Keyboard for Acer Aspire...
I have a Satellite M35X-S114 that has a mic problem. I was using Skype with no problem and then it just stopped working. I hear through the speakers and headset but no mic. I also tried a new headset with...
Sometimes programs like Skype will lose the Mic settings and chose another input channel. Check your operating system's audio settings under something similar to "Recording" and see if microphone is checkboxed and turned up. Also, make sure it is not muted on Skype and/or the operating system.
If you have Windows XP, for example, look for the audio settings icon (little speaker) just left of clock area. Open and go to "options". Choose "properties" then "Recording". Look that your microphone is "Selected" with a checkbox and is turned up. To hear yourself during this, you will need to go back and choose "Playback" instead of "Recording" and de-select "mute" (if checked) for microphone and turn it up to see if you hear yourself talking over the speakers/headphones.
Also, check the Skype settings for microphone and that Skype has the correct sound device selected for input - being your microphone and not another device.
Also make sure that there is not a manual, physical volume adjustment for the microphone on the laptop case itself. Could even be a mute button.
Oct 16, 2009 | Toshiba Computers & Internet
I can hear great but the mic doesn't seem to work. Is there no resolution for this?
I need more info dude, first make sure its not your sound on your computer, you could have your mic muted and you didnt know it, or, try going to your control panel and actually setting up your mic. If its not muted there, i'll need more info, how long have you had the mic, what program are you using to talk to others/record.
Jan 28, 2009 | Logitech 350 (980374-0914) Headset
Laptop acer
Hi please check the audio properties settings of your system . The MIC would have been MUTED . Uncheck the mute against mic and you should be able to record thru the built-in mic.Right click on speaker icon in taskbar audio properties under mic uncheck in the box beside mute.
May 09, 2008 | Acer Aspire 3680 Laptop
Can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
Jan 05, 2008 | Panasonic KX-T7453 Corded Phone
Canon FS100 Flash Media Camcorder Logo
55 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
