Question about Kenmore 46462 Front Load Washer
Kenmore f21 error
Wow it stinks to have found so many identical problems with the same machine. The error codes are spelled out in the service bundle inside front access panel. I tried cleaning pump filter basket, pressure switch mouth to mouth,( and yes I even blew the hose). After mouth to mouth it spun and rinsed, so I put it back together. Back to square 1. Still at it!
  • 333 Answers
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Sep 23, 2009
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
http://media.fotki.com/1_p,wktwwdgrkbbfrdgxgtqsskgwtqkq,vi/kstdgfskbxktqtggsqb/1/1303472/5961857/image64920img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 17, 2010
I keep getting error code F21 on my kenmore elite which is a drain error the drain is not clogged and the drain hose is not clogged any ideas on what I could do?
The error code F21 is similar to F02 which both pertains to a draining problem. The usual cause is a blocked drain filter or a clogged/kinked. But since those areas are found to be not the source of the problem, the problem must be somewhere else. It is either the drain pump is broken particularly the impeller if the pump just hums/whirs or the pressure switch contacts are stuck/welded together and is, therefore, not tripping. The link below provides the detailed troubleshooting instructions the problem of this kind after the drain filter has been cleaned out.
Error Code F02/F21 on Whirlpool Duet and Kenmore Elite Front Load Washers (Filter Cleaned)
Aug 21, 2011 | Kenmore Washing Machines
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
F21 error on kenmore he2plus washmachine. Door locks. Due to no spinning and water remaining in the machine? I run the rinse/drain&spin program (15 minutes) several times. it stays at 15min remaining...
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Mar 23, 2010 | Kenmore HE2 Plus Front Load Washer
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
F21 LONG DRAIN
kinked.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Sep 23, 2009 | Kenmore Washing Machines
Washer don't work (F21) message
The "F21" error is a "Long Drain" error code. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If you still require assistance, please let me know.
Jan 07, 2009 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
