Question about Anchor Vegetarian Cheddar Cheese
Is anchor vegetarian cheese dairy free
Does this product contain milk with renet
How can i attach the milk container
Add a little Petrol-Gel Food Grade Sanitary Lubricant to the two O-Rings on the machine were the milk container connects. If you do not have that available, wet your fingers with water and rub on O-Rings prior to inserting milk container. O-Rings dry out and go bad, they need lubricant. You can get Petrol-Gel at a restaurant wholesaler or Amazon.
O-O
Jun 25, 2014 | DeLonghi ESAM5500
What is plant-based milk?
Plant based milk is produced through plants and is a non diary milk. Some examples of Plant based milk are almond milk, soy milk, rice milk and oat milk.
These milk very widely in macronutrient and micronutrients composition.
Jul 03, 2013 | Wine & Spirits
How does soy milk compare to whole milk as far as nutrition goes?
Let's take a look at the different nutritional values of soy milk compared to whole milk:
Calories- soy milk has fewer calories than whole milk per cup (about 40 calories less per cup).
Fat- soy milk contains 3.5 grams of fat per cup (8 oz.), while whole milk contains 8 grams of fat per cup (8 oz.)
Cholesterol- soy milk contains no cholesterol, while whole milk contains 24 mg cholesterol per cup.
Both soy milk and whole milk contain high amount of calcium per cup that provides about 30-35 percent of the RDA.
Protein- Soy milk has about 5 grams of protein per cup, while whole milk has 8 grams of protein per cup.
Feb 04, 2013 | Cooking
Whats the difference between skim and whole milk?
Skim milk is milk that contains no more than .5% fat by weight, while whole milk contains about 3.5 percent fat. This means that whole milk contains more calories than skim milk (almost half as much). Also, skim milk and whole milk taste differently because of the fat content. Most people prefer whole milk's taste because skim milk is too watery.
I have lactose intolerance. Which dairy products can I consume?
When you're lactose intolerant, you may cringe at the thought of eating dairy products.
But there's really no need. In this day and age, there are plenty of nutrient-rich dairy products you can enjoy, without suffering the all-too-familiar consequences. Those may be Yogurt, Aged cheeses, Low-fat dairy products in small amounts, Lactase-fortified dairy products, Dairy products eaten with a lactase pill, ..
To know how to treat it, see at:
Home Remedies for Lactose Intolerance Authority Remedies
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
I have a DeLonghi Prima Donna coffee machine which is 6 months old. When I plug the milk container nozzle into the machine it is not recognised by the machine. A message on the screen is saying...
Maybe youare not pushing the milk-container sufficiently in. Mine has been increasinglyhard to fit. After speaking with DeLonghi service, they suggested lubricatingthe o-rings on the nozzles on the machine. I asked if cooking oil would be ok,to which they agreed. To I took a cottonstick and dipped it in ordinary cookingoil, and swept it over the inside of the two nozzles on the milk-container,since the o-rings on the machine itself were hard to get to. Now it workssmoothly. I was reluctant to try that out before speaking with DeLonghiservice, since they are so set on only using original stuff for the machine,and I did not think a machine this expensive would need this type of 'help'. Useat your own risk :-)
Flemming.
Nov 09, 2010 | DeLonghi Prima Donna Avante ESAM6700...
My delonghi magnifica is having a problem with milk..steam is coming through but no milk..can you suggest what the problem may be?
There are 'o' rings on the pipes (on machine - not milk container) where the milk container fits into. replace or clean them - should work like new.
Jun 21, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk container won't fit onto front of machine
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
May 02, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Anchor Vegetarian Cheddar Cheese Logo
120 people viewed this question
Top Anchor Cooking Experts
Tom Chichester
ray gallant
Are you an Anchor Cooking Expert? Answer questions, earn points and help others
