Question about Dell F3534 Touchpad
I have my powercord plugged into my Dell Inspiron 1525 but the machine is not getting any power. I checked another powercord to see if it worked and it did not. How do I check to see if the machine had burnt out?
  • 23 Answers
Try doing this... it worked for me...
1. Shut down
2. Unplug
3. Remove battery
4. While battery is out, hold down power button about 10 seconds.
5. Replace battery
6. Turn comp back on
7. Wait one minute
8. Plug in
Posted on Jul 10, 2009
  • 52 Answers
Check the AC adapter (the brick) if its showing light. If it does, try flexing the cable that is connected to your computer. Also, you may isolate the issue by removing the battery. If you can see light on your computer when you turn it on, it means its getting power.
Posted on Jun 14, 2009
INSPIRON 1525 NOT STARTING UP
Try taking the battery out then holding the power button down for 30 seconds (this clears the power in the machine), then power back on and hopefully should work.
Apr 15, 2013 | Dell Inspiron 1525 Notebook
Have a dell inspiron 1525 that will no longer charge, replaced battery, charger and power adapter card in laptop. What can problem be - read that it can be some capacitors. Where are they and how do I...
Tom
i have inspiron 1525 as well ... if the computer wont boot up, then the mainboard may have experienced a power surge of excess current. did you have t-storm or power out while your computer was plugged in with Ac adapter ?
if not , to answer your question, the capacitors you inquire about are so small, it would require special solder machine to replace these CAPACITORs, as they are very tiny in size and require absolute temperature (heat) from solder gun to pally appropriate solder to replace the capacitor(s).
i think your mainboard is gone.
if i can be of further assistance, please let me know-- i can help
Nov 02, 2010 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 laptop is not switching on
unplug the power cable and take out the battery, then press and hold the power bbutton for 30-35 secs. Insert the battery and plug the power cable, check if it works!!
Oct 18, 2010 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
Can a powercord go bad. My daughter has a Dell
It is unlikely that the battery of your Dell had to be changed in year and a half's time. Anyway now that you have a new battery and the laptop is still not functional means that either the charger is faulty (unlikely) or the power on switch is bad (most likely). When you used the new battery first time, did the laptop come on even for a short while. If it did then the charger is faulty. If it did not then the switch may be faulty. Please check and come back to me.
Dec 18, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
