Question about Leisure DWLT65 Dishwasher
Water is not going out of leisure dlt65 dishwasher
Making a funny noise on start up and when programme finished water still in machine
Not emping water
This is a generalize answer, but remove the bottom kick panel to manually rotate the pump motor. In general they can get locked up by objects. Locking up the pump.
May 26, 2014 | Leisure DWLT65 Dishwasher
The dishwasher starts and water gies into the machine but after a couple of minutes it stops. Then a minute or so later it pumps out the water and beeps to show its finished. It does the same thing on all...
What brand have you got? It could be the main spray motor because when the appliance has finished filling it should automaically start the water pumping around.
Nov 04, 2010 | Dishwashers
My dishwasher is making funny noise and leaves
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jun 13, 2010 | GE Nautilus 24" Built-in Dishwasher
E15 error message making a funny noise, is the a
E15 indicates the anti flood device in the base of the appliance has been activated.
Unplug the appliance.
Take the cover below the door off.
Take the insulation out of the way.
Remove any water in the base that is lifting the float.
Once removed, try the appliance again. Watch through the open inspection panel to see if the appliance is leaking.
If the float isn't up activating the switch then the switch, wiring or control board is faulty. Check the float and check the switch.
Your machine is still under warranty so you do need to be careful about what you do.
Trying to repair it on your own may invalidate the warranty.
Hope helps.
Jun 11, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
Jun 29, 2009 | Beko 24 in. D3421F Free-standing...
Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Jun 11, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Strange noise from my Bosch Dishwasher SHU66C02UC/14
It just the pump noise. Since your dishwasher works properly you can ignore this noise.
Sep 09, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Prgramme not starting or finishing
The "mushroom" bottom is just a lever that operate a switch. It seems that a part of the switch's mechanism is broken or release.
Jul 22, 2007 | Bosch 24 in. SGS43C12 Classixx...
Leisure DWLT65 Dishwasher Logo
Top Leisure Dishwashers Experts
Are you a Leisure Dishwasher Expert? Answer questions, earn points and help others
