Question about Logitech Cordless Mouse
Connect a wireless mouse
Connect to laptop
How Can I connect my wireless Logitech mouse to my laptop?
You should search for small wireless USB dongle (receiver) and insert it into USB port of your laptop. You bought The dongle with mouse. Sometimes it is placed inside mouse on bottom side. See picture.
A mouse driver is usually installed automatically in a while after the dongle is connected to PC.
Logitech M310 Silver 1 Wheel USB RF Wireless Mouse Model 910 001675
Jan 18, 2016 | Logitech Cordless Mouse
How to enable a wireless mouse?
No. That model of laptop does not have a special RF transmitter or Bluetooth adapter factory installed, so it has no special way to connect to a wireless mouse. If you have a wireless mouse, and if you wish to use it with this computer, you will need to make sure that the mouse has fully charged batteries, connect a USB receiver for the device to the laptop, wait for the receiver to be recognized by the laptop's operating system and then verify that the mouse is synchronized with the receiver.
Aug 19, 2014 | Gateway Computers & Internet
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
How do I connect a microsoft wireless moblie mouse 3000 to my laptop?
Press the button on the back of the mouse to free the battery cover on top.
Remove the battery cover and put the supplied AA battery into the mouse.
Replace the battery cover.
Insert the wireless USB dongle into a USB port on the laptop or desktop computer.
Move the mouse and watch your computer screen.
Confirm that the mouse is connected by making the cursor move.
Hope this helps
Sep 26, 2012 | Microsoft Wireless Mobile Mouse 3000
Installing wireless mouse on Windows 7 Laptop
connect to the internet with your laptop and then plug in your mouse,windows 7 will automatically find the driver for you :)
Mar 07, 2011 | Computers & Internet
How do i connect my wireless i.t.works optical mouse model MWO03 to my eee laptop windows 7?
Follow these steps :
1.
Check to see if your laptop supports wireless technology (Bluetooth, 802.11 or other). If it doesn't, you will need a wireless receiver. If it does, verify that your laptop is compatible with your wireless mouse, which could use either Bluetooth technology or a radio signal.
2.
Unpack your mouse and open its battery compartment. The wireless mouse won't receive any power from the laptop, making batteries necessary.
3.
Add new batteries to the compartment. Make sure that the + battery end is inserted into the + niche in the compartment.
4.
Place the mouse where it is easy to use and least stressful on your fingers.
5.
Place your wireless receiver appropriately if your laptop doesn't support wireless technology. The receiver should be kept at least 8 inches away from the laptop or any other object that would cause any interference.
6.
Place the wireless receiver anywhere from 8 inches to 6 feet from the mouse.
7.
Insert the driver CD into your laptop and follow the instructions to install the software for running the mouse.
8.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop. If you do not have a free USB port, simply use an external USB hub for more ports.
Nov 07, 2010 | Computers & Internet
I just purchased my first laptop...and do not like the touchpad...I want a wireless mouse...can I use a wireless mouse without being connected to wireless...in other words can I use a wireless mouse while...
Yes, the mouse most likely uses Bluetooth to communicate with your laptop and is independent of your wired/wireless connection to the internet. The mouse should have come with an adapter that plugs into one of your USB ports. Plug it in and once the drivers load (automatically), your new wireless mouse should be working!
Sep 08, 2010 | Computers & Internet
I am thinking of connecting a wireless mouse to my x5dc laptop how do i do it
When you purchase only a wireless mouse it will normally come with a USB connection dongle/adapter which allow your mouse to connect to your Laptop.
Aug 24, 2010 | ASUS Computers & Internet
There isn't connection between the wireless mouse and laptop
First, reload the softwear than came with the mouse. Then, check the cable connections from the receiver to your laptop. If USB, then unplug and replug, if PS-2, unplug, replug, make sure the cord(s) are seated fully in the laptop. Then change the battery in the mouse, push the connect button on the mouse, and you should be back in business. I have Logitech wireless keyboard and laptop and have not had any problems after reinstalling and checking batteries and initiating the reconnect button. You will see a small window on your screen saying the mouse is connected on Channel 1 or 2. I hope this will help you.
Sep 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Unable to connect mouse to acer laptop
Before you connect your wireless mouse USB adapter to your laptop you'll need to install the software first, after the software is installed follow the steps to connect the wireless mouse USB adapter, this will keep the instalation wizard from popping up.
Apr 01, 2009 | Acer Aspire 5500 5570-2609 Laptop
Logitech Cordless Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
