Question about LG hbs-730 Tone Stereo Bluetooth Headset
Distortion when people talk
Is there a setting?
I have a Samsung TV, half of the screen was vaguely showing, I replaced tcon from eBay, I got more of an image on the screen but not fully, so I replaced the main board again from eBay. When I put that...
distorted screen is it settings are wrong, samsung have a special menu setting you use to set up tv parts. and you have to press them in order on the samsung remote to access the setting. changing parts around will alter the setting, as each board is set up for different model. the setting menu is different from model to model but the boards can be in array of models, do a search for you model and the service mode menu code. and use this to change the settings on the main board to setup tv. its like a bios on a computer.
Feb 01, 2018 | Samsung Televison & Video
Scrathy rec audio
older batteries or not fully charged batteries can cause distorted RX. if your batteries are more than 2 yrs old they should be replaced. also dirt or moisture in the radio speaker, or trying to talk beyond their Range can also cause distorted RX. you use most of your power when you transmit.
Mar 13, 2014 | Alinco Radio Communications
Sigmac NE32AB1 Sound Distorted
Interference. Separate wiring in back, so there is no cross-talk of signals. If speakers are failing, go to walmart and buy a new set, <$20.00, hook up and sound is great.
Feb 13, 2014 | Sigmac NE32AB1 32" LCD HDTV
After tv is on for about 4 hours- sound becomes distorted. it has to be turned off then back on agian to restore normal sound..it has been happening since we got tv- which was only 6 months ago
Take it back where u buy it,talk to the store for a replacement,if possible.Or call Toshiba,talk to customer service,describe the problems,ask for a warranty repair.The Tuner board is is the board where the coalax broscast tv signal comming in to this board.It have faulty componnents on it.The board should be replaced.So get the tv replaced buy the store or waranty repair by Toshiba.
Jun 12, 2010 | Toshiba REGZA 47HL167 TV
Changed IC converters, 1-2 message (no problems?)
Are you talking about your convergence ICs ? and Did you use STK392-570s?
Dec 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
Picture flutters and distorted
Capacitors going bad on your DM or FMT board. Very difficult to replace, but Mits does a rebuild on the chassis. I recommend talking to your Mits service center and getting the rebuild done.
Dec 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Olympus FE 200 Microphone distorts when shooting video
Check in the user book if there is a sensitivity adjustment for the sound recording. It is possible that the sensitivity is set too high.
It is also possible that there is something defective in the camera's audio circuits. In this case the camera would have to be sent to the manufacture service rep to fix the fault.
Jerry G.
Feb 25, 2008 | Olympus FE-220 Digital Camera
Mitsubishi vs-45va2
Can you be more specific? What kind of distortion are you talking about?
Jan 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Street pilot i3 has stoped talking
1 had the same issue. Voice sis not appear at all in the settings, just text language was there. Did not want to reset and loose saved data. I plugged in to my PC, installed less maps to leave some memory free, then went throught the install process and selected a different language than US english. After install, it was back and it also talks French. Hope this helps.
Oct 22, 2007 | Garmin StreetPilot i3 GPS Receiver
LG hbs-730 Tone Stereo Bluetooth Headset Logo
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
