Question about RCA D52W23 52" HDTV CRT TV
53inch RCA big screen tv , double vision...you asked me Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it...model # D52W23,Serial # G023CN026 I have the menu but im not sure where to find the conergence adj option..can u tell me where to find that?
  • RCA Master
  • 8,617 Answers
Just press menu and then scroll down to settings and then under settings menu you should be able to see convergence. If not its disappaeared and thats a easy an inexspensive repair.
Posted on Jun 14, 2009
I have an rca 60 inch big screen..it just happen to show double vision looks 3d with out the glasses..lol ....sound is all good just the picture..model number..mm61110 chassis number..mmc102g..i love...
Yes it can be fix, first try to adjust the convergence setting in the setting menu then go to convergence section, adjust the red and blue convergence. You should be able to move the red and the blue convergence up, down and left, right but if you cannot move this far enough the convergence IC is defective and should be replaced. This convergence IC is attached to a large aluminum plate, this is the heat sink and the convergence IC has a marking of STK-#### followed by a number, in order to replace this IC you should have a soldering iron, desoldering pump, soldering lead be careful when pulling out the IC you may accidentally tampered or damage the PCB and caused much damage to the unit. Note before opening the back cover of your tv be sure to unplug it first. But if you are not familiar with electronic parts you can contact a service technician to do it for you and save you from stress good day and best regards.
Aug 30, 2011 | RCA D52W23 52" HDTV CRT TV
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
My RCA projection TV is showing double vision
You can get the STK730-130 convergence IC at the following link which should take care of that issue. Its 24.00
http://servicemanuals.vstore.ca/product_info.php/pName/stk730130/cName/convergence-ics
Jul 12, 2009 | RCA P52920BL 52" Rear Projection...
I have a 53inch RCA big screen tv, we have double vision
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 16, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double vision pretty much
This problem from what you are describing is a convergence issue the customer menu has a option that might help set convergence. if that doesent work a technician may have be called to adjust convergence or see what part has failed in the convergence cuicit
Feb 18, 2008 | RCA R52WM24 52" HDTV Projection Television
Convergance problems?
did you adjust the convergence
on the menu?
Jan 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Magnavox big screen tv
You are having convergence problems. If you can't reset in menu then you may need amps replaced. You can also call PTS18008447871 and ask for price on convergence board and just replace.
Sep 17, 2007 | Philips Magnavox 51MP392H Rear Projection...
RCA D52W23 52" HDTV CRT TV Logo
266 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
