Question about Rural King REI Digital Roof-Mount AM/FM/WB Tractor Radio REC24W
When the ignition switch is turned off the radio looses it programed channel.
I have to reset the channel every time I start the tractor.
Power on, clock works, CD works, NO SOUND from the radio
Check the speaker wires maybe they have worked loose. And speakers themselves as they may blown. Do you have an amp if so check its fuse. Also check for inoperative interior lights, lighter, and horn. One of these circuits will power the radio's memory circuit. Some radio models will appear to work normally but have no sound if the memory fuse is blown. The clue is the clock will reset to 12:00 each time you turn on the ignition switch.
Feb 12, 2017 | Cars & Trucks
I can not get my John Deere 2020 to start. I have replace my battery, rebuilt the starter, and replaced the key switch. What else can I check?
the john deere 2020 gas tractor has a automatic reset breaker. If the tractor has a short it will shut off power to the ignition switch and reset in 60 sec. If the breaker is bad you will have power at the switch until you turn it to start or ecc.then no power at the ignition switch. I can not find the breaker. let me know if you do.
Sep 04, 2012 | John Deere 420,1020,2010,2020,2510,2520...
How do you re program a replacement remote for the APS997A
To program remote; ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off.Test
May 27, 2011 | Car APS997A Two-Way Remote Start and...
I have an identical prestige remote which is not programed for my car iwould like to program it exatly like the one i now use so i can have a spare.
The programming procedure for Prestige/Pursuit remote is as follows:
First, locate the programming/valet switch. For newer model units the programming switch is located in the antenna, previous models have a push button LED (PBLED). Older models have a plain black push button, usually located near the driver's side kick panel (where your left foot would rest when driving).
After locating the programming switch; turn ignition on, press and release switch three (3) times,parking lights will flash once. This is channel 1 (lock button). Press lock button on remote. Parking lights flash once. Press and release switch one (1) time. Two flashes (channel 2). Press unlock button on remote. Press and release switch one (1) time. This is Channel 3 (trunk/remote starter), press the channel three button on remote. Repeat process for additional channels. Once you have programmed all available channels, turn ignition off to exit programming.
Jan 20, 2011 | Gmc Dodge Ford Reverse Back-up Sensor...
5BCR07P PROGRAMMING INSTRUCTIONS
Ignition on, press and release programming switch three times,you will hear one chirp ( channel1), press lock button on remote, press and release switch 1 time ( two chirps, channel 2) press unlock button, press and release switch 1 time (3 chirps), press green remote start button, press and release switch 1 time ( 4 chirps),press option button. Turn ignition off, test.
After pressing the corresponding buttons on the remote programming sequence above ,you should hear confirming chirps from the alarm.
Sep 29, 2010 | 5BCR07P Remote Replacement Transmitter for...
Reset immobiliser
u must put a key to ignition and open a drive door 3 times and press and hold lock button
Jan 18, 2010 | 2007 Ford F
Can i get it to start on channel 1 and not channel 9
You should be able to. It sounds like your radio is hooked up in a manner that disconnects it from ALL the power once the ignition is turned off. This causes the radio to return to channel 9 by default program when powered on again.
Try connecting the radio hotwire to the fusebox at the factory am/fm radio fuse junction (be sure the amps for the cb + the am/fm don't exceed the rating for the fuse). This should keep power supplied to the radio even with the engine off, and it should remain tuned to channel one every time you turn it on.
Oct 15, 2009 | Midland 77-099 CB Radio
Radio Does not work.Door locks only work when ignition is on
i had a similar problem on my ford probe. i found that the fixed live to the radio had split. it left me with only switched power from the ignition. over time it shorted out and i lost radio, central locking and dash lights. i replaced the fuse in the back of radio and had to have the wiring checked! oddly when it was checked over no other faults were found apart from the split live.i replaced the live feed, reconnected the battery and everything was fine. Dont know if this helps but u never know. Good Luck
Jul 12, 2009 | 2004 Dodge Ram 1500
Rural King REI Digital Roof-Mount AM/FM/WB Tractor Radio REC24W Logo
79 people viewed this question
Top Rural King Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rural King Audio Player and Recorder Expert? Answer questions, earn points and help others
