Question about JVC DRMH20 DVD Recorder
Loading fault the unit just comes up with the words loading and will not respond to any functions or buttons.I have changed 4 caps on the power board which had blown tops can some one tell me if any othe caps require changing and what numbers are they I do have a schimatic drawing of the PCB's.Or is this not the fault Please help.
  • menjee May 11, 2010
    did you manage to fix it simon, if so please could you let me know how, thanks.
Check power cables to dvd and hd. voltages should be 12v,gnd,gnd,5V with and without load. if voltages drops with load then fault is probably with caps. I changed one cap when voltage dropped in dvd powercable(5V). cost only 0,50€ to fix powerboard. there is a high risk for electrical shock so if youre not familiar with electrical devices and dont know how to perform these checking operations and so on... then PLEASE take your unit for professional
Posted on Jun 25, 2008
My standby power button stays solid red and will not turn green. No display or sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. /
Dec 25, 2017 | Televison & Video
Control panel is not responding
Most likely, if power *is getting to the unit*, (there are lights lit on the washer), then the culprit will be a shorted user interface board(control panel). This is a fairly common type of issue with dishwashers. The soft-touch buttons or the touch panel has a shorted button or area(depending on the type you have) and nothing else will function because the unit thinks you're still pressing a control button. Also, a VERY common cause of this issue, aside from moisture or bugs, is a power outage damaging the console when power is restored due to a surge. After an outage where damage occurs, the symptoms don't usually start for about 3-4 weeks after due to damaged chips on the board starting to fail.
Aug 20, 2015 | Dishwashers
I have a Kurzweil pc88. The unit function but the power board 7805 voltage regulator overheats and eventually shuts down after 7-8 minutes. All else appears functional. Any suggestions?
Try changing out regulator . Check voltage output and resistors are a good culprit in these cases. Are you sure the rectifiers are doing there job ?
Feb 23, 2015 | Music
Top row of number and letters not responding when I punch them in. for example #1 comes up #4, #2 comes up #5,and #3 comes up #6! How do I resolve?
To calibrate your Streetpilot c-Series touch screen, follow these steps:
    1. Begin with the unit turned OFF and unplugged from a power source.
    2. Power the unit ON, continue to hold the Power button for 1 minute.
    3. A screen will display instructing you to Press dot in the lower left corner.
    4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
    5. Your unit should now function normally.
I hope this helps. Please rate my reply. Thank you.
Jun 27, 2011 | Garmin StreetPilot c340 GPS Receiver
Power button lit and will not respond. No other controls respond.
In most of the computer board controlled appliances in the house today, A good reboot will restore the default settings.
Unplug the washer and let it sit for about 5 minutes to allow the charges to dissipate off of the electronic boards. (capacitors retain a charge for memory).
During this time check to see if the buttons are stuck in the down position. Most of todays buttons are magnetic induction (a magnet completes the circuit when pressed) so the processor may be locked up or confused. Removing power restores the basic instructions.
Another cause/fault my be a safety related issue. The unit will not power on or turn on unless certain conditions are met. The door properly closed, Something in the drum, level... that kind of thing.
Good luck.
Sep 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Television goes blank without warning for undetermined time
Power supply board have problems.Tries, to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC2D Television
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
The only button that will respond is
with controls unlocked, you can not power on or start? ck to see if you can get to diagnostic mode.
old duet(red leds) -select drain/spin cycle, no spin (modifier), press prewash 4 times in 5 secs. all lights come on then displays codes, f code are faults
new duet/sports(green leds) - press and hold any one modifier button 4 sec on 4 sec off 4 times.
control boards are common on whirlpool.
Mar 15, 2009 | Washing Machines
Philips 150B4 White Screen with the word Aging...
I have a philips 19 lcd. the damn thing just display a white screen with the word aging in red in the certer. it goes off after a while, turn black a while then comes back again, with the white screen. keeps doing it over and over.
anybody have any idea?
i tried caps, but all the caps look good.
to be noted i didnt change all.
Apr 20, 2008 | Computers & Internet
JVC DRMH20 DVD Recorder Logo
181 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
