Question about Toro Lawn Mower With Toro Power Tools
Mower will start then starts to putt then cuts off
I have a mower that will start after priming, then once start cutting it begins to putt then cuts off, I have change the spark plug and the filter....I have used a carb cleaner and it also requires engine oil and that has been done as well...can anyone help
  • 1,041 Answers
You will need to disassemble the carburetor and spraywith carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals and/or the jet in carb. These portals canbecome blocked. Replace the diaphragm as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 19, 2009
  • Jim Parker
    Jim Parker Jun 21, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Yard machine riding lawn mower 13a1762f will start, engage blades, once i begin cutting grass mower will run for a minute then shuts off
Try checking the gas tank cap vent hole to see if its clogged. These have a tendency to get clogged with dirt, and when it does the tank start to pull a slight negative vacuum, stopping the flow of gas into the engine. Usually you can just blow it clean.
Aug 12, 2016 | Garden
My riding mower stops moving forward after 30 minutes of cutting it starts right up the blades engage properly and cuts great it will just stop moving
Check under the seat under the battery box there you should find the drive pulleys for the rear end the belt could be worn out and turned inside out causing it to slip or stop pulling once it heats up mine was installed inside out from Lowes when I purchased the mower causing me to replace the belt hope this helps
Sep 16, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Lawn Mower putt putt when filter in place
Your air filter screw may be too long from over tightening air cleaner and crushing the cover. It warpes the carb allowing for gas to leak into carb. Grind or cut off screw alittle or put washer on and don't over tighten. thank you for using fixya.
Jun 12, 2013 | Briggs & Stratton Garden
Qualcast petrol 35s mower will only operate with choke fully open, closing the choke causes the engine to cut out. Mower has been operating fine until now following a full service. What is the likely...
The chole is only ment to be used to prime the engine on cold start up, the engine is supposed to be run with the choke in the normally open position.
Aug 10, 2010 | Garden
Hi, Mum has a wtd wanrite mtt model 548/12hp mower ride
Hi this sounds like there is a spot of dirt in tne fuel system
you will need to dismantle the carburettor which is quite straight forward (be careful not to lose any screws or gaskets
guive the carburettor a good rinse in neat petrol/gasoline and blow out any debris that may be there.
re assemble the carburettor and prime with fuel and you should then be ok.
One other thought if you have found that the motor runs fine without being on the grass (eg it doesn't cut out after a minute or two) then it could be that you have the cutting blades set too low for your first cut. To raise the blade adjust the height of the wheels. Always start cutting with a high setting especially if the lawn hasn't been cut for a while.
hope this helps
W
Jun 12, 2009 | Briggs & Stratton Garden
Toro Lawn Mower With Toro Power Tools Logo
401 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
