Question about T-Mobile Wing Smartphone
T Mobile Wing assembly repair instructions. Where can I find step by step instructions for housing re-assembly.
  • 453 Answers
This is the user manual for the t-mobile wing !!!
http://support.t-mobile.com/doc/tm30168.pdf?&A2L.SERVICE=UserManual
If you need a complete disassembly then here you go. It is quite similar to the Wing
http://www.howardforums.com/showthread.php?t=1152710&page=1&pp=15
Good luck !
Hope you find what you wanted !
Posted on Jun 14, 2009
They locked the sim card to my wing ,how can i unlock it for free
you can unlock your T- mobile with the help of the codes, why i am saying codes means they are simple & easy way, but at a free of cost is not possible for this type of mobiles, do not worry for that one you can get the code at a reasonable cost itself, just visit this site www.theunlockarena.com/t-mobile-wing/rs13wp9 , it has the step by step instructions for unlocking your mobile from the network lock............. Once you get the unlock code after that you can switch your mobile as you wish network...........
Aug 17, 2011 | T-Mobile Wing Smartphone
How do I change front blinker bulb on 2003 chev impala
First,
  1. Turn the engine off and open the hood. Pry up the two fasteners from the radiator air baffle with a flat head screwdriver. Move the baffle to the side to access the top of the headlight case.
  2. Step 2 Pull up the two metal rods behind the headlight case. These secure the case to the car. You may need your pliers to pull them up.
  3. Step 3 Gently pull the headlight case out to access its rear. On the rear, you will find several black dust covers. Twist off the dust cover closest to the fender (the outward dust cover) to access the turn signal bulb.
  4. Step 4 Turn the bulb module counterclockwise to release it. Unplug the electrical connector from the bulb module. Connect the new bulb to the electrical connector (don't touch the glass with your hands; hold it by the plastic piece). Insert the bulb module in the turn signal housing, turn it clockwise and screw the dust cover back on.
  5. Step 5 Insert the headlight case in the mount. Push the pins back down to secure it. Position the radiator baffle in its place and insert the fasteners.
  6. Rear Turn Signal Bulbs
  7. Step 1 Open the trunk. Remove the net from the side mounted wing nut (on the side with the faulty turn signal). Twist the wing nuts (there are two per side) counterclockwise to remove them.
  8. Step 2 Peel the carpet layer back to access the rear signal lamp wing nuts. Twist these wing nuts (two per side) counterclockwise to remove them and release the rear signal.
  9. Step 3 Carefully pull the rear signal assembly away from the Impala. The rear turn signal is the inner bulb (closest to the trunk). Press the tab on the bulb module and turn it counterclockwise to release it from the rear signal assembly.
  10. Step 4 Pull the old bulb straight off the module (don't twist). Insert the new bulb in the module. Depress the tab on the connection and insert the module back in the assembly. Twist it clockwise.
  11. Step 5 Insert the rear signal assembly. Re-attach the assembly's wing nuts and push the carpet layer back in place. Tighten the other two wing nuts to secure the carpet layer and reconnect the cargo net
May 09, 2010 | 2003 Chevrolet Impala
Where can i find a manual for a t-mobile t wing
I was searching for some questions on the wing and came accross this site.
http://safemanuals.com/user-guide-instructions-owner-manual/HTC/WINGS-_E
If you look arond on this web page there is a free download of the Wing Manual. I didn't do the download myself just so you know. Maybe it's was you are looking for. LY
Dec 25, 2008 | T-Mobile Wing™ Smartphone
Please help
I actually just took the whole entire thing apart. I am a female and pretty mechanical. I found it really easy. I am only have 2 problems with the phone now. Half of my keyboard isn't working and the charger connection is loose. Thanks.
Mar 05, 2008 | T-Mobile Wing™ Smartphone
I have lost a button on my wing phone ( the button under the talk button)
I have had the same issue twice now, both times I was able to buy replacement buttons on e bay for about 10 dollars, however there is no instructions, and I think it was my fault it broke the second time because they are so delicate and difficult to replace without breaking a clip. However they are cheap and easy to find on e bay if you wanna chance the repair yourself!!
Mar 02, 2008 | T-Mobile Wing™ Smartphone
T-mobile wing lcd replacement
i went to www.htclcd.com for my replacement LCD only cost $55 and came with the T5 Torx screwdriver
Jan 18, 2008 | T-Mobile Wing™ Smartphone
I CANNOT UNLUCK T-MOBILE WIG
CALL T-MOBILE AND REQUEST THE UNLOCK CODE
Jan 17, 2008 | T-Mobile Wing™ Smartphone
Unlock wing
call t-mobile and they will guide you step by step to unlock your wing. goodluck
Jan 11, 2008 | T-Mobile Wing™ Smartphone
T-Mobile Wing Smartphone Logo
127 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
