Question about SkyGolf SkyCaddie SGX GPS Receiver
Joystick Can I buy one or is there a way to fix it
I dropped my aiptek IS-DV camera and now the joystick that controls the menu functions doesn't work. Is there a way to fix this without buying an entirely new camera?
The only maybe on this is the joystick is out of alignment with the touch points. You will have to take the camera partially apart to investigate if this is the case.
Jan 29, 2014 | Aiptek IS-DV Memory Card Camcorder
My ps2 joystick L3 button stuck when i derict it to any direction .. it suppose to back into its center position but it doesn't it stuck and still unmoved untill i move it back to its original pos
I would suggest buying a new controller if you want to skip the hassle of trying to fix this one, but if you insist on keeping this controller, then there could be a way to fix it. First try your best to smoothly trace the joystick around in a circle, and see if that unsticks it. If this doesn't work, apart from buying a new controller the only other thing to do would be to open the controller up and put lubricant on the bottom of the joystick, this will most likely work, but you might damage your controller in the process.
Oct 11, 2012 | Sony PS2 Dual Shock 2 Controller...
Sir my friend he purchase Toshiba satellite L645D-S4100, 3gb ram, 320gb hdd,windows-7 pls tell me he can fix joystick and he can play GTA game.
YES , Your friend can also use joystick controller for his Toshiba Satelite L645D-S4100 to enjoy playing GTA.
Tell your friend to buy joystick controller so that he can play and enjoy the GTA, please advice your friend as what I advice you.
Thank you for the rating, I really appreciated it.please rate this answer again .. goodluck and have a great day
Oct 26, 2011 | Toshiba Computers & Internet
Hi, I have 2 PS2 controllers, the one was newly bought, the other, has been used for about a year or two. The problem is, the old one's R1 button is unresponsive. Well, it do responds, but only if...
you will need a rubber replacement for your R1 button, if you or a friend have a defective joystick consider that a replacement. if you can't find a defective joystick you can buy a ps2 rubber kit online. below are reference pics.
1. Remove 5 screws with a philip screw at the back of the joystick.
2. Split the two covers with caution.ck
3. Carefully remove the rubber beneath the R1 button and replace it with a new one.
4. Put together the front and back part of the joystick.
5. Test the replaced part and screw if you're satisfied.
Hopefully this information helps.
Thank you for using Fixya..
Aug 03, 2011 | Sony PS2 Dual Shock 2 Controller...
My joystick on my n64 controller is loose . on my legend of zelda ocerina of time my person is walking slowly can u help me fix my controller.
The Nintendo 64 was probably the first system to introduce the Analog Joystick. The joystick unfortunately does wear out after a while. I have seen repair sticks available on the internet, but that would require opening your N64 controller to replace this part. OR you can simply buy a new controller. The following website sells them for around $17 free shipping:
http://store.richspsxparts.com/ni64co.html
Jun 16, 2011 | Nintendo 64 Console
My left joystick keeps moving things down without me moving it
Sometimes your joystick on xbox controllers can become stuck. To fix this you can do one of two things. you can ether buy a can of air used to clean out computer keyboards and spray it inside the analog stick. Sometimes if that does not work you can also disassemble your controller with a t8 torc screwdriver. Ones disassembled use hot water on and below the analog stick to get rid of unwanted grim. This should fix the problem.
May 30, 2011 | Microsoft Xbox 360 Wireless Controller
Most of my games the character will continue to move even though i am not touching teh joystick or D-pad at all...any way to get this to stop?
the joystick is worn and isnt returning to the center as it originally would, it happens to all controllers over time, the only way to fix it is to replace the joystick but it would be easier to just buy a new controller
Feb 26, 2011 | Nintendo 64 Console
The joystick and screen are broken.can they be fixed?
yes, you can take out the screws and pull out the screen and the joystick buy them and replace them
Sep 24, 2010 | Sony PlayStation Portable (PSP) Console
PSP joystick messed up
Okay This has happen to me and what it is the joystick is off track. I'm not saying you guys are handling your psp roughly but it does happen. You can try to repair the joystick yourself.
But the best bet is to buy a new one. Doesn't cost much and it is not hard to do. I paid $3 for a replacement. Word of advice if you are buying a generic brand you may want to buy at least three of then just in case one or more of them are doa (dead on arrival) you never know. Will save to time in returning and waiting for a replacement.
If you want please ask and I will post a how to for repair of your OEM joystick. This doesn't always work but what the hell it's worth a shot.
Dec 20, 2008 | Sony PlayStation Portable (PSP) Console
SkyGolf SkyCaddie SGX GPS Receiver Logo
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
