Question about Kyocera FS-1118MFP Laser Printer
AFTER I CLEANED THE WASTE TONER BOTTLE ON OLLIVETI 18MF D COPIA NOW ITS PRINTING DOTS LINES
IT WAS SHOWING A CODE ERROR C7980 BUT I HAVE CLEANED THE WASTE TONER BOTTLE AND THE CODE IS GONE NOW ITS ONLY PRINTING DOT LINES
    New Friend:
  • 56 Answers
Check if you have put the little pwb inproperly or, in worst case, you have loose it. This pwb is in the left side of the processor unit. You will see a black circle tape near the grey tape of the grid cleaner.
Posted on Sep 23, 2014
IB4G2008
  • 3587 Answers
SOURCE: c-7 980 error code
ok..so you have two kyoceras with issues...let's address the error code first..do you have the users manual handy? It's usually in there. I'll check my reference on that, and also look into the waste toner bottle..
Posted on May 08, 2008
krizanto81
  • 65 Answers
SOURCE: how to clean waste toner bottle
Disposal Tank is on the Process Unit... you will have to remove the screw on the left side then pour it out on the bag...
Posted on Oct 14, 2008
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
n25an
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
Posted on Dec 24, 2009
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
NOW ITS PRINTIND DOTTED LINES
An 1118 process unit has a 100k life @5% average coverage in my experience the usually last about 85k when the waste toner is full it's generally near the end of life of the unit the fact that you're getting black marks in the pages says to me that there is drum decay which is also a signs of the process unit life nearing its end
Mar 22, 2014 | Kyocera FS-1118MFP Laser Printer
Error code 000019 display
When waste toner bottle is full then show this signal.You should clean this waste toner then fix this error code.If you are not fix this problem then clean all surface and it has a sensor.It clean.
Mar 07, 2011 | Canon (6981A002AA) for imagerunner 2200,...
(6981A002AA) for imagerunner 2200, 2800, 3300 Print Server: I have also facing the same problem of Error code ...
So, you need to do next:
Because of statics and plastic bottle, the toner is collected on bottle neck, where is two circles. Even if bottle isnt full but the neck of bottle is dirty the error will occure.
Clean the neck with dry cloath, and then with some antistatic detergent, this will take care of the bottle.
But more permanent solution is to disconnect the waste toner sensor. You will see it above the waste toner bottle.Its a white connector with wires. Pull it out.
But then you need to take a very good care of amount of waste toner in bottle, because if it gets too full it could broke the waste toner gears. So that means that you must every time when you replace the drum, empty the bottle too.
May 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
Canon 2200 error code 000019-0000
This error code means that the waste toner bottle is full. Most likely it is not full, the waste toner bottle neck gets some waste toner on it and it blocks the sensor.... It is a bad design by Canon. The waste toner bottle is on the Left side of the copier, toward the rear of the copier. The cover is held in by one screw, the cover comes off and the Waste Toner Bottle is inside. Turn the copier OFF by the Main Power Switch on the Right side of the copier. Carefully, dump the waste toner out in a plastic bag. Hopefully, without any holes in it. Wipe OFF all the toner OFF the neck of the bottle. You will see what looks like a DOT on each side of the neck.Make sure the inside and out side is clean. Reinstall the bottle and cover and then turn the Main power ON and the Code should be gone. Good Luck....
Mar 29, 2009 | Canon imageRUNNER 2200
Cannot print canon ir2200
toner waste bottle full. Take it out and clean it well particularly around the neck...which is where the sensor is.
Aug 17, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Kyocera FS-1118MFP Laser Printer Logo
97 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
