Question about Savy Soda Documents Free
How to use on iPad
After download I see blank doc. No instructions I need to start at the beginning
How do i put my cv for job applications from i pad when it's in gmail
Your CV needs to be in a file. Most are either DOC or PDF. You can create them using Google Docs and then use it from there or Download the file to your ipad and then upload it to the sites your applying to.
Aug 15, 2014 | Apple Ipad I-pad
Tip
How to convert avi video to ipad
AVI is a multimedia container format introduced by Microsoft as part of its Video for Windows technology. AVI files can contain both audio and video data in a file container that allows audio-with-video playback at the same time. The reason that we need to convert avi to ipad is that ipad does not support AVI video according to apple official document. If you want play AVI video on your fancy iPad, you need to convert video to iPad compatible formats, mostly MP4,MOV and M4V.
This step-by-step guide aims to show you how to use iPad Video Converter to convert AVI to iPad compatible video for you.
Step1. Download and add AVI files to the program. Download the program and run, then click the "Add" button to add AVI video files to the AVI to iPad converter. This iPad video converter supports drag-drop and batch conversion, so you can import and convert several multimedia files at a time.
Step2. Select iPad output format Use the "Convert to" on the bottom of the window to control the output format. Select iPad MPEG (MP4) output format for each video file and specify a directory on your computer to save the output files.
Step3. Start AVI to iPad conversion Click "Start" to begin AVI to iPad video conversion. The convert progress bar shows you how much of the encoding is completed.
on Oct 26, 2010 | Computers & Internet
Its not a phone its aipad16gb rated 5.1v-2.1a class b. just bought it and cannot get into it because it needs a 4 digit passcode and i dont know it just bought it at a yard sale
hi if it's ipad you need download and install Itunes to your pc/laptop Apple United Kingdom iTunes Download iTunes Now then connect ipad to pc, run ITunes and it should detect your tablet you will see it in the right upper corner. Click on it and you will be taken to the summary tab where you will see restore button. click on it and follow the instructions and your ipad will be restored.
Apr 06, 2014 | Apple Ipad A1219 16gb Wi-fi
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Ipad set up instructions
I have 2 ipads and want to set them up so my wife and I can use
the same apple iTunes contract now if I download something
on one it downloads on both
Jan 04, 2014 | Radio Communications
Instructions for use
Go to http://support.apple.com/manuals/#ipad and you will be able to download a manual for your ipad. Hope this helps.
Jan 15, 2013 | Apple iPad (16 GB) WiFi Tablet PC
I need to download free yahoo messenger application for my iPad.
Go to appstorein search box type yahoo messenger.from list choose yahoo messenger.Tap free to begin download.
Oct 07, 2010 | Apple iPad 64 GB WiFi
Open .doc on iPad?
You will need to go to the App store and download a word processing program such as PAGES.
Oct 02, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Using Word & Excel mobile
I saved an empty blank Word doc. and excel sheet. to my phone via Microsoft Active Sync. Now I just open the blank doc. edit the file, and save it as a diffrent file name. I'm still left with the blank doc. and an edited file.
Jul 30, 2008 | T-Mobile Dash Smartphone
Savy Soda Documents Free Logo
97 people viewed this question
Top Savy Soda Apps Experts
Lesley Cameron
Lesley Cameron
ray gallant
Are you a Savy Soda App Expert? Answer questions, earn points and help others
