Question about Weather King 10AJA2501AH Air Conditioner
No heat The AC works fine; I checked the breaker box. The heat came on a couple of times for 10 min or so in the last week but now it won't come on at all. The fan works in the ON position but no heat. Can you give me some idea of what the problem might be and cost to repair before I have to call someone to look at it. It was manufactured 4/2003. Thank you.
  • 1 more comment
  • Yoeman Oct 31, 2007
    It's a heat pump.
  • tapmom Nov 23, 2007
    My heater is gas and it will light but when th blower comes on the fire goes out. Then it just blows out cold air instead of hot. Any suggestions. I checked what i could think of that i could think of and need help.
  • speedytc Dec 21, 2007
    We have the same problem. Ours is a heat pump I think? Weather king Model # Wrka-a030jk06e. only diffrence is ours will blow warm air till Set Point is reached. After it turns off then comes back on again It only blows cold air. We have to shut it off for a while then it will work again. Could this be thermostat problem as well? Unit and thermostat is 11 years old.
  • 447 Answers
First figure out if your unit is a heat pump, (where the unit outside both heats and cools your home) or it may be a propane or nat gas furnace, it could also be a hydronic heater (the water heater heats the home) let me know what you find out.
Posted on Oct 31, 2007
  • joey  shearer
    joey shearer Oct 31, 2007
    Since its a heat pump the outdoor unit should be coming on when you switch to heat. If its not coming on at all it sounds like a low voltage (thermostat wiring) problem. Have you replaced the thermostat recently?? So i take it when you switch the unit to cool both the outdoor and the indoor fan run, however when you switch to heat it does absolutely nothing??? If so it sounds like a thermostat or wiring issue.
Our air conditioner keeps going off, and won't come back on, what is the problem?
does the dryer still wor? you can try switching off the circuit breaker then back on in case the ac is locked out electricaly. do both the dryer and the ac breakers, but this would not be common to two circuits which should be independent.
Apr 22, 2015 | Heating & Cooling
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
2005 Lincoln AC fuse blows
A/C compressor clutch coil going bad . What is the 10amp fuse # F1.01
Nov 18, 2017 | 2005 Lincoln LS
Samsung 2.0TR split ac compressor getting heated up and tripped after running for 10 mins
High limit switch set to high, obstruction in the system, or your compressor may be wearing out.
Apr 12, 2013 | Heating & Cooling
Belling XOU69MF Tripping breaker after on for 30-40 mins after steam cleaning
That's why you use easy off. LOL
If you have run it twice then any moisture should be gone, besides if it was moisture it should trip quick, sounds like a bad element causing the trip. I have never seen a breaker go bad, but they can.
Mar 30, 2013 | Ovens
I have an electric furnace, it worked fine since it was last repaired, had a bad heat sequencer in it.. but now (3weeks later), it is tripping the 30 amp breaker after a few min of operation ????,...
I ran across a similar problem with electric furnaces years ago. One of the heating elements had failed and the coil was actually making contact with the frame in which it was held. This may be the problem but must be checked with the power off as the chassis may be live. Something is definitely amiss if your unit is tripping a 30 amp breaker and probably will show up on a utility bill next month.
Feb 17, 2011 | Heating & Cooling
Outside unit keeps shutting off after 15 to 20 mins.
When compressors are on their way out, this is a symptom that is common.
May 15, 2010 | Carrier 38BRC036 Air Conditioner
Oven will not heat - lights on panel do work
I keep having the same issue with mine, but if I go to the fuse box and flip the breaker off for about 10 seconds and then back on, it works fine. Obviously this isn't a permanent fix but it gets my stove working again for a couple of days usually. I have not been able to find anything on this issue until I saw your post.
Dec 23, 2009 | Whirlpool Accubake RF362LXTT Electric...
Weather King 10AJA2501AH Air Conditioner Logo
118 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
