Question about Magnavox Science & Laboratory
Unable to get the remote to turn on stations etc.
Only the upper right of the set lights up.HDM13
3 Suggested Answers
C-Dog
  • 84 Answers
SOURCE: Channel Changing Problem
You have to go through the set up guide and reset the information you put in. It may have changed. Afterwards you must run through the auto program. This is a common problem i find with customers.
C-Dog
Posted on Feb 10, 2008
  • 2246 Answers
SOURCE: Im trying to instal a logitech 600 remote to my LG
it set to use as output hdmi, chane setting to be a tv use your remote
Posted on Jan 22, 2011
The hand-set on the main station, has a red light on the upper right corner, this light BLANKS all the time. Also, the message in the display window states <Hand Set too far from the Base ...
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 29, 2011 | Uniden Cordless Phone
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
No audio on only some stations
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12/09 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
Oct 29, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Streamium Remote control
Use new batteries for the remote.
May 31, 2008 | Audio Players & Recorders
C-Dog
Feb 10, 2008 | RCA F27442 27" TV
No ethernet with docking station
It could be the connector on the bottom of your laptop that's creating the problem. Does any other ports work on the docking station when docked?
Jan 14, 2008 | IBM ThinkPad T43 Notebook
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
Mitsubishi TV model CY2525
as tv is old please replace it by new kit or whole pcb. now a days you get new pcb(CHINA MADE) at cheap rate with remote & mo of channals more.
Sep 26, 2007 | Televison & Video
Science & Laboratory Logo
343 people viewed this question
Top Magnavox Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Magnavox Science and Laboratory Expert? Answer questions, earn points and help others
