Lcd26805hd manual initial tuning
My LG Television does not recognize local over-the-air stations.
somewhere in the main menu it asks for input . that needs to be set to antenna or air .once you find that and put in the right kind of input then do the autoscan.
Jan 24, 2015 | LG Televison & Video
Hi I have bought acoustics solutions tv second hand model LCD26805HD I cannot retune it can anyone please advise? Thank you
You need the (original correct) remote. Alternatively, you can use a programmable remote, but the ''menu'' must also be compatible with the TV. If you cannot ''navigate'' the Menu and Settings with the remote, you are stuck without a solution. // With the remote you enter the menu ''settings'' and then enter ''channel tuning.'' Then set for either ''manual tuning'' or (best bet) set for ''auto-tuning.''
Jan 01, 2015 | Televison & Video
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
Can only receive forgein channels
See the swection on "Listening to the radio" on page 24 of the manual...
http://www.retrevo.com/support/Onkyo-TX-SR500-Receivers-manual/id/365ag205/t/2/
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Oct 07, 2011 | Onkyo TX-SR500 Receiver
I cant reprogram the scanner. It is only in channel 6
To restore normal operation, try RESETTING the scanner:
- Power the scanner OFF, then power it ON again.
- Insert a pointed object, just as the end of a paperclip, into the RESET opening on the side of the scanner, then push the small button inside the opening.
In many cases, the RESET will restore operation. If not, you'll need to perform the more drastic INITIALIZE process. NOTE: INITIALIZE will erase all information that you've programmed into the scanner and restore it to original factory settings. To INITIALIZE the scanner:
- While holding sown the TUNE/CLEAR key, press the RESET button as above. The scanner display should shut off.
- When the display turn on again, release the TUNE/CLEAR key.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
Bill B
May 22, 2010 | Radio Shack Pro-82 Scanner
I cleared my pro-82 scanner. Program button is not working to let me reprogram. Help.
As long as all frequencies have been cleared, try initializing the scanner. This will return everything to the original factory settings.
To INITIALIZE:
- Turn the scanner OFF, then switch it back ON.
- Hold down the TUNE/CLEAR button.
- While continuing to hold the TUNE/CLEAR button down, insert a pointed object such as a paperclip or the tip of a pen into the RESET opening on the side of the scanner, and press the RESET button inside the opening. The display should go blank.
- When the display comes back on, press the TUNE/CLEAR button again. The scanner should now be ready to accept programming.
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 08, 2010 | Radio Shack Pro-82 Scanner
Lcd26805hd manual FOR A ACOUSTIC SOLUTIONS LCD TV
My acoustic solutions lcd26805hd tv has started flickering really badly every time I switch it on. The flickering goes on for about 30 minutes before it calms down. I have checked all the connections at the back of the tv - all ok. This happens whether I watch cable or a dvd.
Jan 10, 2010 | Televison & Video
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
Tunung VCRs
do you have the hand controller?there should be a tune button or menu button to initiate tuning
Jan 01, 2008 | Televison & Video
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
