Question about Hmdx Hx-p240gy Jam Plus Portable Speaker, Gray
Blinking fast my speaker wont pair and the blue light is blinking fast
How can I get the blinking light to turn off on Bluetooth speaker?
Well first you have to get it to flash red & blue then try to get it to pair with your device
Mar 02, 2016 | Audio Players & Recorders
I have a portable wireless speaker model AWSBT7 will not go into the connect mode when pressing the button to sync up device I do not get the two beeps or the light does not flash faster
Hi Jerry, Are you using this method to pair your device?
Pairing
The Bluetooth-enabled device that you wish to stream audio to your speaker system must
fi rst be paired to the speaker. The process is simple, and in most cases the pairing process
needs to be done only once.
To pair your Bluetooth-enabled device with the speaker:
1. Make sure your device's Bluetooth is turned on. See the wireless and/or network settings
menu on your device to check.
2. If the speaker isn't already on, press the On-Off button to turn it on. You will hear a beep
to indicate the speaker is turned on. The indicator light on the back of the speaker starts
fl ashing blue.
3. Press and hold for 3 seconds the Pair button to enter pairing mode. You will hear 2 beeps
to indicate pairing mode is entered. The indicator on the back of the speaker starts blinking
faster.
4. Open the Bluetooth settings menu on your device. Select "AR SPEAKER" from the list of
devices available (you might have to scan for devices). If your device asks for a password,
enter "0000".
5. A confirmation screen will appear on your device once the speaker and the device are
successfully paired. The blue indicator turns solid blue to indicate successful connection.
The speaker is now ready for you to stream audio from your device.
Oct 24, 2014 | Audio Players & Recorders
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
My jam speaker is paired with my galaxy tab 2. I have been using it To listen to music and it has been working. I turned the speaker of and a couple hours later went to put it on again and when I did the...
I have a similar device. If you didn't un-pair it or you moved the speaker too far away or didn't play music for over 5 minutes it shuts down. It may show that it is paired but doesn't play on the speaker. You have to un-pair and re-pair the speaker for it to work again.
Nov 09, 2013 | Tablets & eReaders
JBL Flip blinking red and blue
This indicates that the Blue tooth pairing with the already paired device has been reset and the JBL Flip is ready for pairing with new device. This position, red and blue blinking, can be obtained by long pressing the power buton.
Mar 03, 2013 | Harman Kardon JBL Flip black
Wont pair with phone
Hello
Please press the power button for 10 seconds then the indication will keep blue instead of flickering. Then you can use your iphone search this earphone.
Mobile Power Mall Solution
Feb 11, 2013 | Motorola Mobility S9 Headphones
Why wont kinivo bth220 wont link with my phone no matter what i try
Can you confirm if you are able to put the BTH220 headphones in pairing mode. Please try the following steps and see if works:
  1. Make sure that the headphones are fully charged.
  2. Switch off the headphones.
  3. Put the headphones in pairing mode by pressing the MFB button (center) for 7-10 secs till you see the red and blue LED blinking alternatively. Please do not leave the button as soon as blue LED appears.
  4. Follow the operating instruction of your Bluetooth device to start the pairing process.
Sep 29, 2012 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Trying to pair b250 xt with samsung rugby2 lots manual
Make sure you device is in visible mode first. In power off condition of headset, press on button for 30 seconds. When blue lights starts blinking fast then search on device and add it.
Custom Car Grilles
Aug 01, 2012 | Parrot Blue B250xt Bluetooth Wireless...
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
Hmdx Hx-p240gy Jam Plus Portable Speaker, Gray Logo
63 people viewed this question
Top Hmdx Home Experts
Donni Steen
Tom Chichester
Are you a Hmdx Home Expert? Answer questions, earn points and help others
