Question about LG HT302SD Theater System
Lens model number missing - LG HT302SD Theater System
Jason Mercury 400 lens
Fixya does not supply spares. Try Ebay or the manufacturer.
Sep 10, 2016 | Optics
I have power supply card psa218-417 -r capacitors c 503 and c 507 are missing
Hi
Not an easy one to get info on.
I will need the model number and a breif description of the fault symptoms ,the board may be a universal used in a number of sets but i need to confirm ,when you say the caps are missing what do you mean,a pic of the board would be a big help.....
Thanks Len.....
Mar 10, 2014 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
The correct serial number on ray ban
look at the box your Ray-Bans came in. There should be a recycling logo, as well as a semi-permanent sticker on the box, including the serial number, manufacturer and distributor details, lens and frame type, and the model number of your specific style of sunglasses. If this sticker is missing, the sunglasses in the box are probably not genuine.
Jun 11, 2012 | Ray-Ban Clothing Accessories
How to change the brightes
A fairly old model is listed here(KP-61v85) this answer is based on that model number:
If the set has not been serviced for a long time with set unplugged remove rear cover and locate (hard to miss) the three large black lens at top of chassis--clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
If the lens are dusty/dirty they will diminish the brightness and clarity of the the picture---they are the light source for the picture in this set.
Apr 11, 2012 | Sony KP-61V85 61" Rear Projection...
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
Hi - is it possible to remove the lens from an Olympus C-7070 camera? I want to try to fit it on to an inverted microscope with a bayonet fitting. Thanks, Paul
The lens is not designed to be removed and the camera will not function if you do manage to do so as it will report a lens error. To avoid this will involve bypassing various microswitches, simulating missing inputs and making other custom modifications to your camera. It's not impossible but you'll be on your own with the modifications, adapting and inventing as you go.
Ideally you either need a suitable SLR with an adaptor, or a camera which will accept an adaptor onto the front filter fitting (not all compacts and bridge cameras have them though).
You'd best contact Olympus directly for suggestions: they're a major microscope manufacturer and have always had the best solutions for using their cameras with microscopes. They have in the past produced a surprising number of microscope adapters for their models and have often produced special versions of their cameras designed solely for use with microscopes, endoscopes and similar non-standard applications.
Aug 24, 2010 | Olympus C-180 1.70x Lens Converter
I have a old 61 inch tv the lens are out. Are these lens still available numbers on them are 646376-1 delta 24 passed 08121490 by U S Precision Lens inc Cinn. Oh.
The lens isnt the problem the tubes(CRTs) are what go bad. Whats your model number I may be able to help you out. The other site I work at has a huge inventory of used picture tubes that are all in good working order. Finding new tubes for anything older than 97 models is almost impossible. But post your model number and I should be able to help you out.
Apr 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Old vivitar lens to adapt to a new digital camera
You don't need the serial number, you need the model number. Look for numbers inscribed on the ring around the lens opening or on the body of the lens somewhere.
Mar 28, 2008 | Cameras
Parts and service manual of Nikon ED AFNikkor 80-200mm 1:2.8 D zoom lens
Nikon Parts
841 Apollo Street, Suite 100, El Segundo CA 90245
(310) 414-8107, (310) 322-6979
Jan 19, 2008 | Nikon 80-200mm f/2.8D AFED Lens
LG HT302SD Theater System Logo
18 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
