Question about Calvin Klein Watches
Replace change battery
Open watch and replace battery
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
Le clip, swiss watch, how battery change
It is probably difficult because they have to try hard to keep water out!
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 19, 2010 | Watches
I have a Geneve watch and need to change the battery. The case seems to have no way of opening it and seems to be one piece and I took it to the jewelers and they can't replace the battery. Is there any...
Of course, there is the way to change the battery, but for this you have to visit your closest watch repair shop. I do mean WATCH REPAIRS, not the jewellers. Decent watchmaker will definitely open your watch and will replace the battery. Your watch's case appears to be a monoblock. That means you'll need to lift the crystal first, pull the stem second and just then you'll be able to extract watch's movement for replacing battery. Do not forget: jewellers and watchmakers are under one roof, but their trades are completely different. No jeweller can do watchmakers job and vice versa. Rate me, plz.
How to do you open the case to change the battery?
Mar 02, 2010 | Al Agnew Al Ag 3 Piece Pocket Watch...
How do I change the quartz battery on a Longines La Grande Class
Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
Hope it may helps;
Regards;
VOTIT
Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Battery change for Nixon Kink watch
You have to open your watch caseback. Undo the battery holding contact, get the battery out and memorise the writings on the battery. Buy exactly the same one and replace it in the backwards way you took it out.
Do not forget to rate, please.
Feb 28, 2009 | Nixon A155 Wrist Watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
How to take off back to change battery on pulsar v783-x009 watch
Don't even try. I take mine to the watch kiosk at sears. They open and replace the battery for a very reasonable price.
Apr 18, 2008 | Watches
Watches Logo
22 people viewed this question
Top Calvin Klein Watches Experts
Joseph Hoffmann
aravind shet
aravind shet
Are you a Calvin Klein Watch Expert? Answer questions, earn points and help others
