Question about Broncolor IRX-2 Infrared Transmitter B36.116.00
How do set up the broncolor irc 2? We have it linked with the broncolor pulsoA4 (power pack) but when we take a picture using the camera nothing happens? Do we have to use the sync cable ?
We have the infrared synced with the power packs but when we take a picture using the camera nothing flashes? Occationally we get a flash, but thats if we are right next to the power pack.
Broncolor Impact 41 fires by itself.
Ir sensor causing self flashing.Press sensor button to switch off Infra red sensor unit will stop self flashing.
Feb 28, 2011 | Broncolor Cameras
Vivitar series1 Pro-648-CAN. The camera and flash attached were dropped. The flash seperated from the camera. Nothing visually broken or damaged. Reattached the flash and the pictures are VERY over...
You have to check if the camera is broken or the flash.
To check the camera, remove the flash and take pictures in normal daylight environment. If the pictures are normal, by that I mean focus and exposure, then the problem is your flash not in sync with the camera.
Not knowing what type of flash you have whether it is infrared or manual will tell if there is a sync problem. It is easier to replace a flash then a camera. Good Luck
Jan 07, 2011 | Vivitar Cameras
I placed new batteries into the camera, however after one or two uses when I turn the camera back on, the camera says the batteries are exhausted and powers off.
Digital cameras use batteries p very quickly. Some batteries last longer than others. I buy large multi packs at the big box store near me. When you say two uses, do you mean just two pictures or two uses taking several pictures? You can go to your cameras menu and navigate through it to adjust several of the settings which will save power. You should also be sure that your battery setting is correct while you are there.
Look through your manual to read about the menu settings and battery usage.
Thank you for using FixYa.
Dec 27, 2010 | GE A1455 Digital Camera
I have a Canon EOS 40D camera. We are having problems with using an external flash. The pictures always come out extremely dark with the external flash. The flash seems to work fine, it flashes...
I don't know if this will help and this post is two months old. The camera store may be right that the synchronization is the issue which tends me to point a finger at the external flash. There are at least three different flash units that will flash when the picture is made but only one type will sync with the camera. A digital flash unit is different from a film flash so a Canon EX type is required to sync with Canon TTL or TTL II digital cameras. An EZ will flash but it's off a bit, so I can only assume that your Promaster and Canon flash units are for film cameras. Okay and another thing that could be throwing things off a bit is the camera may have been programed in Custom Functions to use "Second Curtain" or "Rear Curtain". Just seams to me if the built in flash works then it's the external units at fault.
Oct 17, 2010 | Canon EOS 40D Digital Camera
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
I Downloaded my photos to my computer and when I
Remove the battery from the Camera then press and hold the power button for 30 seconds.
Then, reinsert the Battery pack and try to reset the camera to the original factory settings before using it.
Oct 01, 2009 | Kodak EasyShare One Digital Camera
D300, SB-800 fires but no exposure.
Thats is odd.
When you hook everything up, do you turn on the flash last?
It sounds like the battery pack is giving the flash a different voltage then it should have causing incorrect readings and exposures.
I would send the pack back to Quantum(located in Ronkonkoma, NY) and have them check it.
Jul 13, 2009 | Nikon Speedlight SB-800 TTL Flash
Broncolor IRX-2 Infrared Transmitter B36.116.00 Logo
Top Broncolor Cameras Experts
Are you a Broncolor Camera Expert? Answer questions, earn points and help others
