Question about Dell Dimension 8400 PC Desktop
Sonic, Dell Dimension 8400, Philips DVD +- RW burner
Often says ''no media in drive'' when there is, and always, always crashes entire computer after completed DVD is ''finalized''...and then DVD (or CD) won't play in any non-computer.
What to do?
  • 98 Answers
Are you copying ,copy writed material?then you need dvd descripter.
Posted on Jun 15, 2009
So i have a dvd-rw drive in my computer and i just got the whole computer(dell dimension c521) but it is telling everything else that it is a cd-rw , or something like that, drive. when i put a dvd in the...
If i was you i would replace it........I recently had to replace mine and i picked up a brand new Sony DVD/RW for only $24 If youve never fitted 1 its so easy just 2 plugs which can only go 1 way and a couple of screws....... cheers and please vote
Jul 13, 2011 | Dell Dimension C521 PC Desktop
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I...
those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Apr 14, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I have a Dell Dimension 8400 P4 3.2G w/XP Media Center V2002. Just replace the HD due to a crash of orig HD. Cannot get the TV to work. Get the following error msg - Decoder Error - The video decoder has...
Sounds like the driver for the TV Tuner is not installed, or the video and audio drivers may not be installed properly.
Mine was always a bit wonky in XP, works like a charm in Vista or Windows 7 though
Jan 26, 2010 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Dell 8400 , does not show having the CD or DVD players.
Either get a new Drive because it is spoilt or format the Com. Try the first option first.
Jun 08, 2009 | Dell Dimension 8400 PC Desktop
Sonic record now program will not find cd drive
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. Your media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. Lower the write speed of your burner.
  5. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  6. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  7. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Mar 24, 2009 | Dell Dimension 2400 PC Desktop
Dell ~ Cant Save to Drives D or E
Try restoring your PC to a date when it last worked, probably corrupt drivers or can also be caused by installing or uninstalling software or your Anti-Virus or Internet Security program
start --> All Programs --> Accessories --> System Tools --> System Restore
Click Restore my computer to an earlier dat
Click Next
Choose a sutable date and then on the right click a restore point
Click next
and leave to restore
Feb 08, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Dell won't acknowledge installed DVD/RW Driver
try running this patch..
http://dell.driversdown.com/dell-drivers-downloads/Roxio-Easy-CD-Creator-5.3.4-Patch-Upgrade_23173.shtml
or try calling Dell Tech. They normally remotely access your system and run a patch and your dvd drive will show up in Sonic/Roxio
Nov 22, 2008 | Dell 16X DVD±RW Serial ATA Internal Drive...
Slow burner
well what you can try is
1.) Cleaning your registery out
2.) deleting all temp files
3.) defragmenting your registery
to do all the above you can use a product know as tune up utilities aviable here www.phazeddl,com type yune up in the search box and search it
4.) defragmenting your harddrive
to to this go into my computer
right click on local disc and click properties.
clicl tools the defrag
5 delete your preftech files
they are located in c:\windows\prefetch
6 empty your recycle bin
7 restart
ensure you have 16x media and your burningspeed is set to 16x
4x media means you can only burn at 4 8x at 8 or below, 16x at 16 or below
if all fails then you need to format and reinstall
dont forget to rate me
Jan 07, 2008 | Dell Dimension 8400 PC Desktop
CD burner
Sounds like an issue with the drive. Is your computer still under warranty? If so then I would call dell and get it replaced. If not, then I would replace it myself.
Jan 12, 2007 | Dell (1Y414) DVD+RW Burner
Dell Dimension 8400 PC Desktop Logo
128 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
