Question about Body Sculpture Bt3152 Motorised Treadmill
No power I put the treadmill down for family party and since I put it back up it is not working. It is all connected but when I put the safety pin in nothing happens.
Tread mill power is on but treadmill not moving just beeping
Does it need a safety key? Is it in all the way?
you might also need to check the connections in the back of the display and also where they connect inside the front arms down to the motor.
Apr 14, 2014 | Exercise & Fitness
Proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Oct 13, 2012 | ProForm 70 Perspective Treadmill
Where's the safety latch for a Nordictrack T7si Treadmill?
The fold up latch is on the underside of the walking surface. There is a chrome tube that has a pull knob on the side of it to release the treadmill and allow you to fold it down. You do need to lift the weight of the deck slightly to allow the pin to work freely. Once the pin is pulled you can ease the walking surface down flat.
Hope this helps.
Feb 23, 2011 | Nordic Track NordicTrack T7 si Treadmill
My Nordic Track C2200 Treadmill will stop in mid run. The timing when it happens is random. I can pull the safety tab out and put it back in and run for a bit till it stops again. Any suggestions on...
It it completely shuts down ( console shuts down then restarts) it may be a static electricity problem. Check your outlet to be sure it is grounded. Check the plug . The ground pin may have been removed.
Jan 02, 2011 | Nordic Track Exercise & Fitness
How do you get the running deck down?
If you are saying that the deck is in the folded position and will not fold down then pull the pin on the left side of the deck. If the pin is stuck then try and plug in the treadmill insert the safety key and push the down incline button on the console. This should make it so that the pin will un-jam.
Aug 21, 2010 | Proform iLog 750 Treadmill
My treadmill is stuck on a 10 incline and will not come down
incline motor is bad or needs calibrated, try this
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
Aug 04, 2010 | Nordic Track NordicTrack Treadmill, A2550
Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Feb 28, 2010 | Exercise & Fitness
Bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Jun 14, 2009 | Bowflex Treadmill Series 7
Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Apr 27, 2009 | Proform Sport 1000 Folding Treadmill...
Body Sculpture Bt3152 Motorised Treadmill Logo
23 people viewed this question
Top Body Sculpture Exercise & Fitness Experts
Electro Med Services...
John
ray gallant
Are you a Body Sculpture Exercise and Fitnes Expert? Answer questions, earn points and help others
