Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Water tank Light stays on
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
After filling water tank and replacing on Senso coffee maker the indicator window still shows "water needed" and will not heat water or brew?
I think the problem might be with the sensor in the water tank, you might need to replace it or send it to be replaced.
Jun 15, 2014 | Philips Senseo HD-7810 Coffee Maker
Empty water tank light stays on
The only thing thats comes to mind is the reed switch and the float on the water tank. Check the float make sure the magnet is working, if yes then the reed switch on the inside of the machine is not in the correct position.
Dec 30, 2009 | Solis Palazzo Espresso Machine
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Descale red light, wont go off, and can i use any delcale tabs
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Mar 12, 2009 | Bosch Coffee Makers & Espresso Machines
Water fill light stays on all the time and compresser will not come on
water fill light stays on how can I fix this problem ?There is no water in the internal tank or the external tank.Please help
Sep 10, 2008 | Danby Heating & Cooling
Bosch tassimo
Sep 03, 2008 | Braun Tassimo Espresso Machine/Coffee...
Water tank stay's on
2 things. Water tank has a magnet in it (little rectangle black plastic piece on the backside). Thats gone bad. need a new water tank.
2nd is you need a water tank gasket.
Gasket is easy to fix, flathead screwdriver.
May 13, 2008 | Saeco Magic De Luxe Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
