Question about Motorola Mobility SLVR L7 Cellular Phone
Camera doesn't work
Most of the Forums i've read people describe the same problems with the camera on their phones not working as a result of water damage, but my phone has never taken a bath, or even gotten splashed with water, but the camera, and video camera do not work. It comes up for a moment, and then gives an error message that says     Busy. Try Again.  I thought that this could be caused by lack of memory, so i deleted almost all of the media off of my phone, or moved it to the SIM card, but the error message and camera/video camera remain inoperable. After trying this, I also did a Master Reset of the phone, but this gave me the same results. Help would be much apriciated!
  • 167 Answers
Re: Camera doesn't work
Camera prob. some camera prob' caused by lack of memory,
camera damage, comera in not connected properly' cause by bending, drop.
some L7 camera prob.' is on the program of the phone.
If there is technician nearby' try to change your phone camera.
Posted on Jan 12, 2008
0 characters
3 Points
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage( Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Blackberry curve 9360 camera not working
As Mustgo describes, this is a hardware problem. I followed his/her advice, only I did not take out the batt, just powered the device off, and instead of a cloth, I used a cotton swab made with a plastic rod, not a wooden one.
I applied some gentle pressure with the swab directly on the camera. There was no snapping sound at all, but the camera came back, jerkily I have to say, but at least it was working once again.
Against better judgement, I tried to "improve" the results by applying some more pressure with the camera on: BAD idea! it took a picture of my stupid face and then froze with that picture on the screen. Fortunately, a reset (alt-shift-delete) was all it took to make it work again. So be strongly cautioned: if you don't succeed at the first attempt, turn off the phone, and try increasing the pressure gradually until it works... and when you've achived that result, please just let it sit for a while.
After some hours of not using it, it's now showing image faster and it has not failed again.
Good luck
Jun 06, 2012 | Cell Phones
Samsung S8000 Camera is not working. I don't know why.
Try to go to the camera settings of your phone and try some adjustments or try to update the soft your phones camera, but if it doesn't work maybe your cellphone camera has a hardware problem.
Jul 01, 2011 | Samsung Jet S8000 Cell Phone
Camera Module Not Ready, Help me pleace
You try this:
  1. Dial *### Go to Factory Settings
  2. Click on select type sensor at last
  3. Choose gekewei and press ok. confirm it ( press ok twice )
  4. Now you are ready to use camera
If the above steps doesn't work, the problem can be repired by flashing with original flash file read from another phone(same model..)
Here are some links for more information about flashing:
Jun 28, 2011 | Nokia N95 Cellular Phone
I have an lg cosmos touch. When I turn my camera on it loads for like two or three seconds then this thing pops up it says camera start error. I've tried turning it off then back on again that...
Jun 03, 2011 | Cell Phones
I got the Topram 16GB Class 4 C4 MicroSDHC MicroSD Card for my env3 phone. When I put the card into my env3 I can't use it. Under memory usage it reads 0mb for total used and available. I tried formatting...
We are having the same problem. I researched the problem online and in the Verizon Forums and we are not alone. We are on our 3rd Verizon LG Envy 3 (Sept 2011) and 2nd 16GB memory card (from ebay- both cards worked perfectly in our Blitz and Samsung Glyde)......and we still are out of luck. Verizon acts like this is the first they've heard of the Envy 3 - 4GB/8GB/16GB memory card problem. Evidently, Verizon doesn't pay any attention to their own forums. The Verizon Representative even got very irritated that we were on our 3rd Envy 3 phone (the lights would not work on the keyboard on 1st one) and that we were still calling with problems. I am in the process of filing complaints about the Verizon Rep and the Envy 3 memory card problems. Bottom line.......still looking for a fix!! The phone should recognize the sd card without you having to pull it up manually, both our Blitz and Glyde cell phones did. Oh, one more thing......the Envy 3 recognized a 1GB sd memory card but not the 4GB and above.
Jan 11, 2011 | LG enV3 VX9200 Cell Phone
C902 doesn't start, blue camera light shines
flash your phone.i had the same problem,and after flash it worked fine. for tips on how to, go to
Dec 06, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Hello fixya i;ve recently bought a nokia6280, the problem i have now is the camera wont work now, when i press the camera button to come on, it now comes on the screen 'operation failed' then 'camera on...
The problem I have my two nokia6280 all want to use an object comes Alkamirh
nokia6280 camera standby
We have entered into some forums and saw a large number had the same problem
Some of them give them some advice, some of the modernization Insahohm to take the company
Do you find the solution
Jul 14, 2008 | Cell Phones
3250 camera problem
its the memory card mate. I've been getting the same problem. Having looked at other forums, it appears to be a problem with the actual phone too - the memory card gets corrupted too easily and then screws up the phones hard drive. I bought a new memory card today and replaced it and the camera now works fine - unfortunately the new memory card doesn't work, but at least it seems to cut out the fault that was originally occuring.
May 14, 2008 | Nokia 3250 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
163 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
