Technics SL-EH 50 wont stay on.
When pressing the power button on the System goes on for a second then goes off again. shows FG1
  • 6 Answers
SOURCE: technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
Posted on Jun 03, 2008
SOURCE: technics sl-dv 290
I think your dvd is set to a different region. This might help:
1. Insert disk
2.Wait for 'no play'message
3.Immediately press stop
4.It wi go to chapter review automatically in about 5seconds time u should be able to press play and start the movie
Hope this helps
Miss didi
Posted on Nov 09, 2008
tempo123
SOURCE: technics sa dv280 hard reset
DESOLDER THE REGULATOR AND CHECK IT OUT AGAIN IF IT'S OK THEN REPLACE THAT BIG GREY AMP PART STICK TO THE RADIAROR ON THE BACK
Posted on Dec 13, 2008
SOURCE: Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
Posted on May 04, 2009
  • 89 Answers
SOURCE: pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
Posted on May 17, 2009
When I turn on my Technics DV290 stereo it shows FG1 what does that mean.
Codes are not listed, you would need the troubleshooting manual, which they do not give the public access to.
Jul 09, 2017 | Technics Audio Players & Recorders
How do i get the connector of the end of ribbon cable for technics sl eh 760
i've got one, or did you mean....off the end..?
the top plastic bit pops off, take a photo of it first so you know which way round it went on.
Jan 17, 2014 | Audio Players & Recorders
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
My Technics SL-PD987 5-Disc, does not read CD any more. First did not read burned CD, after did not read original CD.
Power the unit off. Unplug it. Press the power button for 30 seconds. Plug it back in and try again.
If this doesn't resolve the problem, I recommend a CD cleaner. This is a CD that has a small brush attached. It will clean the dust from the laser reader.
If this doesn't work, I'd suggest a professional repair shop.
Apr 15, 2011 | Technics SL-PD987 5-Disc CD Changer
Technics SL-DZ1200 Turntable Wont Start Up
Hi Derrek,
I have exactly the same problem, I was wondering if you have found a fix for it? I have to cut the power 2 or 3 times before it starts up and then it seems to work perfectly! Very strange...
I would really appreciate any help,
Many thanks,
Fred
May 08, 2010 | Technics SL-DZ1200 Turntable
Technics SL-1700 Mk2, tonearm doesn't lower, cueing doesn't work
There's a rubber belt or O ring that broke. I couldn't find one at Technics, so I took the old parts to the hardware store and found an O ring in plumbing parts that was very close. Been working for years just fine!
Eddie
Jul 16, 2009 | Technics Audio Players & Recorders
Technics sa dv280 hard reset
Nov 16, 2008 | Technics SC-EH780 CD Shelf System
Technics sl-dv 290
1. Insert disk
Hope this helps
Miss didi
Nov 01, 2008 | Technics SC-DV290 System
Demo will not turn off
Hello!, i'm the same problem with a eh-770 before a cut of electric fluid. I resolved the problem setting the clock of the unit.
Jun 07, 2008 | Technics Audio Players & Recorders
13 people viewed this question
 Grubhead
Grubhead
