Question about Dryers
Kelvinator dryer No power to the unit. Replaced the plug and light still does not come on.
Kelvinator auto Sensing Dryer ED55 trips the fuse in the fusebox as soon as the dryer is turned on. All other appliances switched off therefore not overload.
check that it is not a fuse but a circuit breaker ( earth leakage breaker) that protects not only against overload but against faulty machines
if there is moisture, bad insulation , incorrect installation or anything that could cause an electric shock that unit will shut down the power supply
call an electrician to find the fault
Oct 18, 2016 | Dryers
The light in my Kelvinator fridge will no longer work, can it be fixed, globe has been replaced , also
Barbara: You can remove the globe and replace the light bulb with an appliance light bulb. If it still doesn't work, try wriggling the socket a little bit with the light bulb in place (so you don't get shocked). If it STILL does not work, yes, a socket can be replaced and rewiring can be done.
May 25, 2015 | Kelvinator Refrigerators
Whirlpool gas dryer: 120 volt plugged into a 220 volt plug. Dryer will no longer show power for machine. inside light does come on when plugged back into 120 volt receptacle. Has the dryer burnt up?
may have burned the motor out.... if this unit has a control board on it most likely would have shorted it out first if a standard/basic gas dryer will a timer knob then power would have either burned timer,or motor up first.... good luck to you that really stinks....
Feb 07, 2011 | Dryers
KELVINATOR GAS DRYER. IGNITORLIGHTS UP THEN TURNS OFF. NO HEAT.
the ignitor needs to be glowing white hot not orange. it is not hot enough to ignite so you need to replace it.
Oct 04, 2009 | Frigidaire FGQ1442ES Gas Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Whirlpool Duet Dryer not working
I would say youwould save money by having a technician from a reputable company come and check the unit. you could have multiple problems from what you did when it was wired wrong.
May 28, 2009 | Whirlpool GEW9250P Electric Dryer
Kelvinator Washing Machine has no power
unplug the washer and plug something else you know works in to make sure you have power in the outlet if not
check your circuit breaker box and reset the switch that is not lined up with the others flip it on off on
Now check the washer If you haven't already done this.
Some units have there own fuse in the back , if so it will be labeled.
hope this helps if not get back to me mike
Jun 11, 2017 | Washing Machines
Dryers Logo
15 people viewed this question
Top Dryers Experts
