Question about AOpen MX3W Pro-E (91.88210.241) Motherboard
Processors over 800 Mhz wont work in mx3w pro-v motherboard
800Mhz processor is fine but processors over 800 Mhz wont work in mx3w pro-v motherboard. I suspect its a bios problem but where do I get an update from? If the bios is the problem.
When I write 'wont work' what I mean is that I get a black screen after booting the PC with a processor faster than 800 Mhz installed in the system.
I look forward to your comments regarding this enquiry.
    Novelist:
    Champion:
  • 256 Answers
XXXXXXXXXXXXXXXXXXXXXXXX
Posted on Jun 16, 2009
  • CONSTANTIN SPYROU Jun 16, 2009
    If you remember I had some jokers that tried to make fun of my ways. I know that I am a little or more excentric in my thinking and my doing things. But I will assure you that what I design always ahs worked in the past.
    Now, about the 800 Mhz: if the system has a cut off frequency of less than 800 Mhz, then the system does not work because the rquired frequency has to be higher than 800 Mhz. If you try to use a processors of 800 Mhz in a 400Mhz environment then the 800 Mhz with "hang up" and burn out due to overheating.
    Now in the other scheme of things a processor made for 800 Mhz, when applied with a much higher frequency to it, not only will get hot from the high rate of switching and most likely burn out, but if the frequency is high enough, it could also hang up (i.e. the plip flops inside it will stop switching and they will let a high current through the one status, with the possible result to burn out the processor, just the same.
    We, therefore, have a window of safe operation, which, if designed properly for an 800 Mhz "center frequency", it could operate safely down to may be 500 Mhz and toward the top, up to may be 1200 Mhz.
    In all of these cases we assume that the proper heat exchange apparatus (heat sing and blower). If the heat exchanger is not designed properly then it will also cause the CPU chip will.
    I received this same question, but I did not see any failure having occured. Therefore, the judge says that if there is no corpus delicti, then there is no crime and I did consider the whole thing to be a simple waste of time, when we had other clients, desperately needing help.
    As I have said before, I can work much better if I have guides, to guide me.
    CONSTANTIN SPYROU
  • CONSTANTIN SPYROU Jun 18, 2009
    A processor made to operate at 800 Mhz. If another processor much faster than the 800 Mhz was placed
    in its place of 800 Mhz, the operation will be erratic (missing counts) due to the higher frequency design, it
    is possible that it will not follow the lower frequency and it is possible to get got, because its cycle of
    conduction will be wider and could get hot and possibly even burn out. If a lower frequency processor is
    placed in the place of the 800 Mhz, the operation will be erratic, could get hot because of the higher angle of conduction and it also could even burn out. So, we have to watch it both ways. Today there is a way to
    strain every hertz out of a processor, by speeding up the clock, a process known as "overclocking".
    Nothing changes out of the theoretical explanation. The heat sink will have to most likely be re-done. At
    times a cryogenic generator may be necessary. The whole thing in a nut shell is that we have to find some
    way to get the heat out of the CPU chip... We can safely say that the CPU chip is not operated like a switch
    turned on and off, it rather is operated as a variable resistor and this is the reason for the generation of excessive heat, that we have to be extremely careful in removing it, or we could damage it...
    CONSTANTIN SPYROU
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I dont have mother board driver for system model awrdacpi
The Intel® Desktop Board D915GAG supports one Intel processor in an LGA775 socket. See the table below for a complete list of supported processors.
Processors not specifically listed by type and rated speed can have requirements that are not supported by the design of the desktop board. Use of unsupported processors can result in improper operation, damage to the desktop board or processor, or reduced product life.
Processor Family System Bus Frequency L2 Cache Size BIOS Version Intel® Pentium® 4 800 MHz 2 MB 0391 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0477 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0475 or greater
533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater
DOWNLOAD LINK IS GIVEN BELOW...........
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D915GAG%22
Sep 22, 2011 | Intel D915GAG Socket 775 Motherboard -...
I m using A open MX3W pro -v motherboard ... In that pentium 3 processer is not working ... But celeron is working
Try adjusting the CPU Frequency in Bios Setup for your processor. You can also try downloading the lastest BIOS release from http://global.aopen.com/userdownload_List.aspx?RecNo=2931&Model=244
May 13, 2010 | AOpen MX3W Pro-E (91.88210.241)...
Motherboard p3v4x : during bootup i get a system
This error is usually caused by an incorrect setting of either bus speed or multiplier (or sometimes processor chip operating voltage). These could be set either by software ie in BIOS or by changing tiny switches mounted on the motherboard.
Have you consulted your motherboard manual?
Try here: http://www.motherboards.org/files/manuals/1/p3v4x-102.pdf
or try the ASUS website and look under support or the discussion forums.
This will help: http://support.asus.com/cpusupport/cpusupport.aspx
These freq and voltage settings are set under BIOS which is usually accessed by hitting the DELETE key on your keyboard after turning on your computer.
Sometimes a quick fix is to enter BIOS as per the above instruction and selecting LOAD BIOS DEFAULTS or something similar to that and then save and exit BIOS and allow the computer to reboot.. That may get you to the point of booting up without the improper freq comb error.
If you have no luck playing with the above info, shut down your computer and remove the left hand side cover on your computer box or tower, so you can access the inner workings of your computer.
Remove the cooling fan from your processor chip. It will be a large square or circular (black or silver colour).
Take a look at your processor chip. Note the part number printed on the chip, which is only visible after you remove the cooling fan. For example it may say for example SL52P or something else. It may also be an AMD chip.
Search the internet for its specifications ie search for SL52P.
For example, if it was a Pentium 3 chip running at 800 Mhz go to google and search for specs of P3 800 Mhz processor with the part number SL52P.
Google returns the following info (based on the example above) of:
http://processorfinder.intel.com/details.aspx?sSpec=SL52P
ie its a chip that runs at 800Mhz speed with the memory running at 133 Mhz (800 mhz processor speed obtained by having the multiplier set to 6 but actually means the memory is running at 133 MHZ but the processor running at 6 times the speed of the memory bus ie 133x6=800 MHZ (one of the settings you need to get right in your BIOS settings)
So if you had this chip, in BIOS you would select 133 bus speed, with the multiplier of 6 usually locked down on the processor physical internal wiring.
If your BIOS doesnt allow you to play with the processor and memory bus settings (commonly done to make the processor overclock to a faster speed) the other option is that you have the DIP switches on your motherboard set to the wrong settings. Again, refer to to your motherboard manual. The DIP switches are tiny plastic switch blocks on the motherboard with a row of (usually) white sliding switches.
Intel chip info: http://www.intel.com/p/en_US/support?iid=hdr-AP+support
http://processorfinder.intel.com/List.aspx?ParentRadio=All&ProcFam=483&SearchKey=
Also Try this: http://processorfinder.intel.com/Default.aspx
Cheers,
Steve (Melbourne, Australia)
May 09, 2010 | ASUS Computers & Internet
I m using A open MX3W PRO -V motherboard ... in that pentium 3 processer is not working ... but celeron is working
The processor socket type must match the board design - The P3 processor may not be the equivalent type.
Mar 23, 2010 | AOpen MX3W Pro-E (91.88210.241)...
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Not a good outcome, sorry. Just stating the facts.
Jan 08, 2010 | Dell Dimension 2300 PC Desktop
Cant run 3E GHz 800 FSB L2 cache 1MB cpu on a ASUS P4P800s-x
here are the specs.
CPU FSB DDR DIMM Type Memory Frq.
800Mhz PC3200/PC2700/PC2100 400/333/266 Mhz
533Mhz PC2700/PC2100 333/266 Mhz
400Mhz PC2100 266 Mhz
the CPC and the moemories meets these spec. then you shouldn't have problem.
since you didn't spec the meories. I am assuming that the meories are within specs.
but, from what you say about, I suspect the memories is not up to part. looks like the meories are in PC 2100 range.
Nov 14, 2008 | ASUS P4P800S-X (610839118175) Motherboard
Who to overclocke my motherboard'z FSB or my processor?
Hello.
It is not save for your system making it work faster by overclocking it.
Some times it works fine just using the right cooling methods, but some times its leads to system freezes, crashes and even to permanent processor damage.
So i advice you to keep that in mind.
If you want to proceed anyway.
- In newest computers you will find an option to set the processor speed to automatic( system recognize the cpu speed) or manually, in the last one you hve to set the RATIO( Processor speed divided by FSB speed), this means:
- The FSB of your P3 Motherbord (133 Mhz) x 7.5(ratio)= 1Ghz
- In older motherboards the speed option is set using jumpers
configuration in the Board, inthat case you will have to use the motherboard manual( some boards have printed tables) to show you the config.
Note: if your motherboard doesn't show you the RATIO you need is because it doesn't support that speed.
Good look.
Jul 04, 2008 | VIA C3, 800 MHz (VIAC3800) OEM / Unboxed...
Hang/reboot
What type or modelof motherboard did you use now?
Feb 19, 2008 | Intel Pentium III, 800MHz (229725001)
OVERCLOCKING
The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
Oct 28, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
AOpen MX3W Pro-E (91.88210.241) Motherboard Logo
192 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
