Question about Altec Lansing ThreePiece Speaker System for ComputersMP3 players (Black) (MX6021)
Mx6021 power board burn
How to connect a new power card. and how many voltage out put and how many amper
Mx6021 power supply burn
The cost to repair these speakers would be prohibitive. Get a replacement system on ebay.
Mar 22, 2014 | Altec Lansing MX6021 200 Watts RMS 2.1...
My aser 7730 will not turn on? When the charger is plugged into the laptop the light on the charger flickers? Is this a mother board issue or power jack or what ? Help !
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Oct 12, 2010 | Computers & Internet
My baterry won't charge... Connected to AC adapter.. WIndows 7 shows plugged in and cheging but battery charge won't go up. I have replaced battery and AC adapter both but still same issue.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 24, 2010 | Toshiba Satellite M115-S3144 Notebook
Hello I have the problem of battery back up. i cant use my laptop widout charging point connected. plz tel me way to solve it.
Sep 21, 2010 | Lenovo 3000 Y410 Laptop
It will not power on. will not take a charge. I have removed the battery and it will not even indicate the power cord is connected
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 18, 2010 | Velocity Micro Notemagix M10 Gx Netbook
Hey hi this is nammy........my acer 4736z battery is not charging.....actually whn i plug in, the orange light comes for a while and it shows tht battery is charging but after a few seconds it loses...
Sep 15, 2010 | Acer Aspire 4730-4947 Notebook
Laptop wont turn on, with battery one light flashes green for a second without battery and connected to the mains it does nothing.
Sep 05, 2010 | Acer Aspire5100 Notebook
When connected to power my computer often drops to battery mode. I have changed the adaptor but it doesnt charge consistently
Sep 02, 2010 | Dell Inspiron 6400 Notebook
Yes..My Toshiba jus stop charging. The port were I plug the Home charger into is not grasping the connection. What do you think the problem may be ?
Aug 28, 2010 | Toshiba Computers & Internet
Have power problems with my Pavilion dv 5016 EA laptop.New battery but battery power runs down even when operationg connected to AC power
Aug 22, 2010 | HP Computers & Internet
Altec Lansing ThreePiece Speaker System for ComputersMP3 players (Black) (MX6021) Logo
41 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
