Question about Port Designs Computers & Internet
Changhong Can't get USB port to work. Does not come up in source???
Why does screen say no media device when I have iPad connected to usb port of ELEFT326 TV
USB on that TV is for a USB flash.
Page 11 in the manual says:
Insert the USB flash drive into the USB port, select USB channel source via the SOURCE button.
It doesn't say what it will read off a flash drive though.
Sep 05, 2016 | Televison & Video
I can not find an HDM1 port on my Sharp TV. Can I use the USB Port?
No, the HDMI plug will not fit into a USB port. (It's the wrong shape and the pins are different.) The micro-USB port can be connected to some USB ports for power, not data, with the appropriate cable (micro USB to type A). (Without the model of your Sharp TV, I do not know if the USB port has the right specifications. Some older TVs only have a "service port" which doesn't always provide enough power.)
There are HDMI to component video/audio converters that may work. They do not always work with copy protected (HDCP) content. See http://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html for one example. (Composite video is not recommended since that will downgrade the signal to 480i. Component video supports 1080p signals.)
If you have 1 HDMI port, then a multi-port HDMI switch may work. Note: automatic switches often do not switch on their own with some sources. If the source never actually turns off, like some set-top boxes, you'll need to switch the unit manually.
I hope this helps.
Mar 05, 2016 | Amazon Fire TV Stick
CONNECT I PHONE TO VIZIO TV USB PORT AND WATCH NETFLIX.
Vizio doesn't support phone connect - only USB drive (ie thumbdrive type) - With correct USB, TV will show USB as a 'Source' - and if selected will show the files on the USB, but can only open / view folders, images, and video types.
Nov 25, 2014 | Vizio E421VO - 42in Lcd 1080p 60hz Hdtv
Printer not talking to desk top.
Please check usb cable first, make sure that it is ok. Then check usb port,move the usb cable to other port. Then check if usb cable and port are ok, try to connect other printer or device by using that usb cable and port. If works well means the usb port on printer got a problem. But if still not work the problem could be on usb cable or usb port on computer.
If you are sure that both the printer and computer are ok, try to reinstall the printer driver. Good luck!.
Source: Printer Clinic - Where printer problem get solved
Sep 18, 2012 | Canon Pixma MX310 All in One
Source not found I am using an Acer Aspire One
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
May 16, 2011 | Vivitek D825MS Projector
Computer is saying it has malfunctioned.
Well, it probably does have a problem if it worked on this same computer before without a problem. You could try the memory stick in the following to isolate the source:
1) try in a different USB port (to see if it is USB port related - only this port has failed - others ports will work).
2) try in a port on a different USB controller (to see if it is USB controller related - all ports on this controller will fail. Other ports on other controllers will work).
3) try in a different computer (to see if it is related to the USB stick itself ).
4) repeat the process with known good USB device such as a mouse or other storage device (this will confirm or cast doubt on the results found above).
That's about all you can do. Retire or replace the source of the problem. I hope thgis helps - good luck!
Jan 12, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
The flip mino hd usb won't plug into most of my usb ports (And yes, I know the difference between a firewire and usb). I have tried it on four different computers with a total of 10 usb ports. it worked...
My flip mino hd USB also will not plug into my MacBook Pro.  I've tried it on 3 different machines and it will only fit into one port, and not at all easy into that port.  When I look at the USB connector on the device, there appears to be slight raised plastic ridged on the outside ends of the connector.
Dec 26, 2009 | Pure Digital Flip Mino Digital Camera
It says the twain is not connected
check your usb cable is working fine .
Also check USB port on cpu works fine.
try all usb ports 1 by 1.
If stil same issue then uninstall driver then reinstall driver.
Let me know if you havent driver setup source.
Aug 24, 2009 | Canon CanoScan D646U Flatbed Scanner
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
Computers & Internet Logo
Top Port Designs Computers & Internet Experts
Martin Murray
Prashant M
Prashant M
Jax Planet
Jax Planet
Are you a Port Designs Computer and Internet Expert? Answer questions, earn points and help others
