El rodamiento del tambor - Washing Machines
puertobori
  • 7733 Answers
SOURCE: tengo una impresora dell
1-Apague su PC
2-Desconecte la impresora y el tambor
3-Prenda su PC
4-Conecte la impresora
5-Ponga el tambor
Suerte
Posted on Oct 07, 2010
puertobori
  • 7733 Answers
SOURCE: se puede resetear el contador de los tambores de
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Posted on Dec 01, 2010
Cogz
  • 1326 Answers
SOURCE: Buenas nochess. tengo una canonimageruner 1023
Hola, a E019 means that the waste toner is full. The waste toner holder is part of the drum unit. You can vac. it out, but you most likely need a new drum unit. Good Luck
Posted on Dec 13, 2010
bbl242003
  • 1637 Answers
SOURCE: puedo reemplazar el tambor de color amarilo nada
Cuando se reemplaza el amarillo, lo que ocurre cuando intenta imprimir?
Posted on Jan 12, 2011
Andriod Man
  • 271 Answers
SOURCE: Mi secadora Whirlpool care II
posiblemente sea que la correa del tambor se rompio. tambien pudiera ser que la usaron sin el filtro(lint screen) y se trago una media u otra pieza de ropa y esta atrapada en el abanico del motor o se le rompio la parte tensora de la correa. de todas formas tiene que desarmala para ver que tiene. suerte.
Posted on Feb 06, 2011
Mi lavadora funciona, pero cuando llega al ciclo de torcer hace un ruido como que golpea y parece que camina lavadora whirlpool w10250884
Hola '
Suena como los cojinetes en la parte trasera del tambor se han derrumbado.
Si el tambor est? suelto y ruidoso cuando se gira a mano significa que los rodamientos han desgastado.
Este es un gran trabajo y probablemente ser?a m?s barato comprar una nueva m?quina.
Buena suerte.
Nomess
Feb 24, 2015 | Whirlpool Washing Machines
Ruido en el freno trasero derecho de un toyota 2003
Es util saber si tienes frenos de tambor o de disco. Si es de tambor tienes que revisar el desgaste de las zapatas y tambien ver que este bien armado. Puede haber polvo o algun material que no debe estar alli. Si son discos puedes ver el desgaste a travez del caliper. Espero que esto sirva.
Apr 16, 2014 | 2003 Toyota Corolla
BANDA DE UNOS 4 CENTIMETROS EN LA QUE SALE MAS CLARO O NO IMPRIME.
  • Puede ser que el cartucho de toner se esta quedando vacio ( en este caso sacalo de la impresora y movelo un poco hacia los costados, insertalo en la maquina), tambien fijate si el rodillo de revelacion del cartucho tiene toner en toda la superficie.
  • Otro problema puede ser que el laser no se proyecte en el tambor de imagen (para este caso chequea que nada obstruya el paso del mismo)
  • Y por ultimo el Laser, estan sucios o empañados los espejos del mismo (limpiar con un trapo seco que no deje residuos).
Sep 07, 2011 | Xerox Office Equipment & Supplies
Mi secadora Whirlpool care II se oye el motor funcionando pero no gira el tambor de adentro
Feb 06, 2011 | Whirlpool Dryers
Fotocopiadora Toshiba E.352, saca manchadas las copias en ambos extremos superior e inferior, pág. tamaño carta.
Lo mas seguro es que el area del tambor o el fusor ya necesiten un mantenimiento, puede ser solo limpieza o lubricacion hasta un cambio de refacciones por desgaste.
Sin embargo te dare un tip, si tus problemas son solo en las partes superior e inferior, cambia el tamaño de papel carta de LT LTR, es decir, de posicion vertical a posicion horizontal, y programa este nuevo tamaño en la copiadora desde el boton de userfunction, user, drawers y selecciona el nuevo tamaño.
Suerte y recuerda que este tip es solo temporal, considera de todas formas el mantenimiento de estas areas mencionadas
Nov 26, 2010 | Toshiba e-Studio 350 Copier
Tengo una impresora dell dice error 004-321 le quito el tambor la prendo me pide el tambor y repite lo mismo
1-Apague su PC
3-Prenda su PC
5-Ponga el tambor
Suerte
Oct 06, 2010 | Dell 3000cn Laser Printer
Zanussi td 4212 no calienta la recistencia esta bien lae comprobado y no esta cortada los termostatos estan bien me podeis decir donde lleva el rearme de la recistencia que no lo encuentro y si puede ser...
Hola, supongo que ya la habrás arreglado, dejo esto para futuras consultas.
La secadora tiene, ademas de los termostatos de la resistencia, un termostato de seguridad dentro del tambor, por encima de la puerta, es bastante facil de desmontar y comprobar, la mia tenía esa avería.
Suerte
Sep 09, 2010 | Zanussi TC7102W Electric Dryer
How do i remove the rear drums off of a 2004 toyota matrix?
Pull the tire off.  Once the tire is off look at the drum where the studs come out and you wheel see a locking ring around one of the studs.  When you find it cut it off.  I usually use diagonal cutting pliers to take them off.  Once you have done this the drum will not just slip off usually.  I would get a soft face hammer and tap around the drum hard enough to brake it loose.  While you are tapping on the drum use you free hand and start trying to pull the drum off.  If it is still stuck on there you can get a big screwdriver and put it in between the drum and axel Assembly and turn the screwdriver.  Dont pry on anything just turn the screwdriver so that the drum will slide straight back and off.
Dec 23, 2009 | 2004 Toyota Matrix
Tiene bibracion o los esprines estan fuera de lugar o el balance del tanque esta mal puesto no se con las imagenes del sistema creo poder
Podria ser que una pieza parecida a una "y" que sostiene el tambor interno en la parte posterior del mismo se haya corroido por contacto de bimetales ya que la "y" normalmente es en aluminio y el tambor en acero inoxidable. La unica forma de accesar esta pieza es desarmando practicamente toda la lavadora para accesar el tanque y luego separar la cubierta plastica para accesar el tambor. No necesariamente tiene que ser esto, esperemos que no... Tambien podria ser un soporte interno roto. De cualquier forma, remueve la cubierta inferior (si la tiene) y echale un vistazo a los soportes.
Apr 21, 2009 | Kenmore Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
