Question about Sewing Machines
Pfaff sewing machine
Loading 4d system onto new computer dongle will not upgrade to new 4d system Message is dongle not found even tho red light on dongle is on
  • Sewing Machines Master
  • 7,365 Answers
You may need some type of a update or patch, try contact pfaff customer service
Posted on May 07, 2014
SOURCE: Have 3D software,Pfaff 2140 machine and Hus Designer Diamond mach
I have loaded the 4D software and have communication with my Husquvarna machine through that. I communicate with my Pfaff through the old 3D software on my computer.
Posted on Nov 24, 2008
azach
SOURCE: Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Posted on Jan 15, 2009
  • 3 Answers
SOURCE: no communication between pfaff 7570 and computer
It sounds like you have it configured properly if you have the little machine and computer appearing on the display screen. I had this problem too in the beginning, file assistant doesn't use the files for the 7570 its only for some of the newer machines, use Vip customize to send the design to the machine from the file drop down menu. Hope this helps.
Posted on Mar 05, 2009
  • 13 Answers
SOURCE: Manual Sewing machine Pfaff 1229
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on May 27, 2009
  • 14 Answers
SOURCE: Dongle won't work with 4D Embroidery
Unfortunately some people are having this problem when they are not properly installing the updates. It's important that when 4D is installed that you assign a particular port for your 4D dongle and always use this port when loading 4D. Have your dongle plugged in and access your configure menu. Click on Smart Update. Download updates into a file where you can find them. Follow the directions for each update. For the driver update, you must uninstall the current driver you have and then install the update for the driver. If installing the updates doesn't fix your problem, the only solution is to completely uninstall 4D and all of its components and then reinstall it. Sorry...but this has been the only way to fix it with some systems. Also, make sure your User Account Control is off before installing 4D.
Posted on Sep 10, 2009
I purchased a used pfaff creative vision machine and it came with the 4d embroidery software but no dongle. I am confused - is a dongle the same as a usb flash drive?
Or a way to connect to another device such as a computer. Could be an "adaptor" to connect to usb cable. Is the software on a CD-ROM? If so you will need to move the appropriate software most likely via setup program to the Paff machine. The software may help explain the connection, there may also be troubleshooting instructions on the disk in PDF format. Still stuck try MFG website and or email their customer service.
Jun 14, 2015 | PfaFF Sewing Machines
How do I activate my dongle for 4D Monogramming and Vision software when it tells me that I can't?
I don't have 4D, so this is a guess, but I do use a lot of different embroidery design software programs. That message sounds like possibly the software has not been installed. If you're positive all was completely installed, It might be a good idea to call 4D support for their advice. If you are installing on a new computer be sure the software is compatible with your operating system. You might need to uninstall and reinstall and if so this PDF for 4D Installation Instructions might help: http://www.learn4d.com/media/How$20to$20install$204D$20Monogram$20and$20Vision.pdf
Jul 10, 2014 | Husqvarna Sewing Machines
Windows 8 Laptop Computer won't recognize 5D dongle or 4D dongle.
I used this link for the same problem. Download and install. Resolved my problem immediately.
http://sentinelcustomer.safenet-inc.com/DownloadNotice.aspx?dlD=8589947873
Dec 08, 2013 | Husqvarna Viking 1
My laptop which has windows 7 on it does not recognize mmy dongle
there is an update for windows 7 and dongles at the husqvarna viking website.
From Husqvarna Viking website -
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
link to latest Dongle Drivers - http://vsmsoftware.net/downloads/HASP/HASPUsersetup.exe
Husqvarna Viking - http://www.husqvarnaviking.com
If you are still unable to get it to work, visit your local authorized Husqvarna Viking dealer. Most stores have staff who are eager to help but you might want to call for an appointment
Good luck..
Feb 13, 2010 | Husqvarna Designer I
Loaded autodigitizing onto our new computer with Windows 7. Everything loaded just fine but when I try to open program it does not recognize the dongle.
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
Feb 09, 2010 | Husqvarna Designer I
I have the Husq Pro software for my #1+ machine and I bought a new computer with 64 bit. I can't get it installed. What do I do?
Good luck.
Jan 23, 2010 | Husqvarna Viking 1
I need a driver for a husquvarna 3D reader/writer card, where can I find one
Dongle issues - http://www.husqvarnaviking.com/global/8588_4197.htm
Good luck.
Dec 10, 2009 | Husqvarna Viking 1
Oct 08, 2008 | Sewing Machines
Sewing Machines Logo
62 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
