Question about LG 42-inch Flat Screen Led-lcd Tv - 1080p 120hz Hdtv
Zenith 46 inch tv won't turn on
Was on, turned itself off, and unable to turn on
  • 47 Answers
Check caps in power supply.
Posted on May 26, 2014
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: My LG TV a 46 inch keeps turning off after a
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Jan 18, 2012
I have Sony LCD tv
Any other indications? It looks like it turns itself into 'stand-by' having no input signal.
May 29, 2015 | Sony BRAVIA KDL-46BX450 46 inch LCD HDTV...
My zenith plasma tv turns off right after i turn it on
There are many reasons for this fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 07, 2015 | Zenith Z60PV220 60-inch Plasma TV
Have zenith tv with zenith remote working fine. Wrong buttons were pushed trying turn off tv in the dark. Now remote doesn't work. Good batteries. H24F36DT. Ztv. And Zenith tv remote! Non universal..!
I don't have one of these, so a couple of guesses: turn on TV from front panel and attempt to turn off from remote. If that doesn't work turn on TV from front panel and look for setup menus which may have gotten trashed somehow. Take batteries out of remote and leave out for an hour. to see if it resets itself. Have you called Zenith help line?
Service manual: http://www.go-gddq.com/upload/2009_08/09082716157372.pdf
Feb 08, 2015 | Zenith Televison & Video
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
Unable to turn off set up menu zenith a27a23w tv
go unplugg the tv and turn it on and bam fixed
Apr 08, 2010 | Zenith A27A23W 27" TV
46 inch projection lcd, says tempature is to hot at bottom of scr
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jul 02, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Zenith tv
There is alot of reasons as to why set will not come on you need a repairman.Check ac fuse see if it is ok., which i dout but you might get lucky .
Oct 01, 2008 | Zenith Z46Z83D 46" Rear Projection...
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
LG 42-inch Flat Screen Led-lcd Tv - 1080p 120hz Hdtv Logo
79 people viewed this question
Computer Repairing
Computer Repairing
