Question about JVC KD-G120 CD Player
C.d. i connected all the wires and plugged it into the car. the only thing it does when i turn on the c.d. player is the light just blinks off and on constantly. whats the problem?
  • 365 Answers
Ground is insufficient
Posted on Jun 14, 2009
Did that seems like the turn signal works everything the fog lights blink with right turn signal on
you haven't said what your vehicle is , usually when this type of thing happens it is a faulty earth connection at the turn signal bulb fitting, this is easy to check , remove the bulbs and turn the turn signal on and see if the fog lights still blink, if they dont then is a problem with the earth at the bulb holder , check for the condition of the earth wire and its connection to the body, hope this helps
Jun 25, 2016 | Cars & Trucks
There are only 5 wires from truck. Red, black,
aaaa more info your new plug should be marked as to what to connect to , DONT drive your self insane do one wire at a time and with a test light im guessing this is a rv flat spaded plug as i said start with one thing at a time turn on just running lights not headlights running lights that will put power in on wire only and that you want to connect to your plug running lites next shut off lights ,turn on a signal light signals will be a blinking light only on one wire.
Oct 08, 2014 | Cars & Trucks
Power light blinking on sony dvd player
Repair of a portable unit with a power supply problem inside it is likely not to be economical and parts for these units are rarely available.
No magic wand for this issue--unless was a very expensive unit replace it--
May 02, 2012 | Sony DVP-FX930 Portable DVD Player
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
My problem is I bought a truck and the wiring in the back was played with so the trailers lights would work for him,and I had the wires apart and looking for burnt out bulbs signal lights do not work they...
Take his wiring off of the truck. If it is a plug in harness, bypass it. See if the lights work correctly now. If not, check each light for a loose connection. If they work correctly, go get another harness. Hope this helps, Mike
Apr 11, 2011 | 1999 Chevrolet S-10 Pickup
How to identify rear turn signal and stop light wires in trunk to connect trailer lights
in the trunk there should be a multi plug near the lights on the left and right side, disconnect the plug, turn on the left or right indicator depending on what side you are working on first, use a test light (they are about $5 from your auto store) find a good earth on the vehicle body and connect the alligator clip on the test light to the earth, use the probe on the test light and touch each terminal in the multi plug until the test light blinks, that will be your blinker wire for that side, when you have found them see which colour wire it is and tag them.
Now turn of your indicators and turn on your park lights, use the same method as you used for the blinkers and tag either wire as you will only need one for the parking lights.
Now turn off the parking lights and get a friend to apply the footbrake, use the same method again and tak one wire as you only need the one for the brakes.
Now just connect the wires from the trailer to the wires in the vehicle and remember to connect the earth wire from the vehicle connector plug to the vehicle body
Oct 08, 2010 | 2000 Mercury Grand Marquis
2003 ford explorer sport turn signals blink rear brake lights
The ford explorer sport track. Will have a short either at the plug of the multi-function switch or 6 inches down where the column bends the wires during tilt.
Sep 05, 2009 | 2003 Ford Explorer Sport
Creative Zen Vision M 30GB wont turn on
Problem could be the combination of a bug that causes the device to freeze and the battery running out. If...
- the player won't turn on
- the player won't connect to PC
- the standard reset action won't work,
plugging the player in the AC charger may pull up the recovery screen which will allow you to proceed and reboot, provided the player has no other eg hardware issues.
Aug 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Kenwood kdc-mp232 not turning on
check your connections. i believe only the standby wire is connected.. or the built in amplifier detects a short on the speaker wires.
Jul 18, 2008 | Kenwood KDC-MP232 CD Player
JVC KD-G120 CD Player Logo
85 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
