Jvc tv repair model LT - 47DG1 starts up ok then after 10mins has lines across the screen and image distorted. can you suggest why?
Was hooked up to blue ray DVD. Even on its own still does the same thing. Is it worth repairing
  • 275 Answers
SOURCE: JVC 27"
Repaiur or replacement? It's Your call! If you know Solid State repairs, then worth a try. Most likely a bad Electrolytic capacitor in the Vertical Oscillator / Output section. Do not waste time identifying faulty one, but change all at one go. Even if one is faulty, the others must have started drying up, and will cause problems in the future.Remember "An Ounce of prevention is better than......"
Posted on Oct 02, 2006
  • 6 Answers
SOURCE: plasmaa tv not going
Try using a ground isolator. You can buy them at radio shack, or your local hardware store for under 10 bucks. this item has three holes on one side and two posts on the other. it takes the ground out of the tv. We call those a scrolling line or a hum. Can be caused by incorrect wiring in the tv or the wires that run to the tv, could be running with electrical lines or an hvac unit. try this solution if it doesnt work then go to the altrenative which is sending the unit out for repair.
Posted on Dec 12, 2007
  • 6 Answers
SOURCE: THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Posted on Feb 15, 2008
jhoi
  • 11 Answers
SOURCE: jvc lcd cracked screen
LCD is one of the expensive part of a Monitor. maybe you can buy a new one because if you choose to repair it, it cost the same when you buy a new one.
Posted on Feb 27, 2008
SOURCE: olevia tv repair
CHANGE TO A ROOMSHOW
Posted on Mar 09, 2008
Jvc lt-40fh97 40" LCD Hdtv
You need a repair guy for this one.
Feb 28, 2008 | Televison & Video
JVC LT-42E910 LED flat screen TV, backlight comes on, menu box is displayed but after about 5 seconds backlight goes out. Picture and sound still working but no backlight. How can I troubleshoot?
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Jan 11, 2016 | JVC Televison & Video
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
Vertical jitters on picture - JVC AV48P776
What you are experiancing is loss of High voltage. The line is called a retrace line. It is usally caused by failure of the flyback circuit or aging of the TV tube. This is the single most common failure with CRT based display systems. The high voltage can be tweaked up, to accomidate for the age of the tube. Its a short term solution. Because of the high voltage nature of this circuit, suggest a professional repair.
Jun 29, 2009 | JVC AV48P777 Television
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
Orion TV model TV_798 sl (thin line no picture)
problem is with the vertical output circuit. take it to a repair shop and have them fix it.
Sep 15, 2007 | JVC AV-27D302 27" TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
