Question about Boating
Marine engine PCM 343 excalibur starts popping sound after 3,500 revs. Changed distributer set and plugs but no cahange.Today temperature went up to 200 Degrees Celsius. Anyone know of the same problem?
  • 19 Answers
SOURCE: Error Codes 9-343
This error code can be caused for a number of reasons:
- Replace the IBT assembly (as Kemo mentioned). The alignment holes on the bottom inboard side of the IBT are used to position the 2nd BTR. the holes may not be positioning the 2nd BTR in the proper location. Once you replace the IBT the cam gear and the clutch drive gear should mesh properly.
- Main Motor If this motor is too slow to start up, then the 2nd BTR sensor sees it as a slow 2nd BTR movement. resulting in the error code. This would only apply if:While watching the machine warm up, you will notice that the 2nd BTR assembly cycles about 4 times before coming into ready.
-At power on, machine immediately declares a 9-343 code. The second BTR assembly cams in continuously. A piece of paper has logged itself behind the service panel connector plug.
Remove logged sheet of paper from behind service module plug.
*** This is the type of problem where you should really have an expert assist, someone who knows the hardware of the machine and has access to the possible parts required to resolve.
*** NOTE: I only listed a few possible resolutions, however it could be the PWB causing this among other variables. I recommend contacting the manufacturer for assistance.
I hope this helps.
Posted on Nov 24, 2008
  • 3 Answers
SOURCE: we own a samsung cooltech
Im no expert, but you can try this, take the back bottom cover off and you will see two drairn pipes going into a drip tray. remove those pipes ( just pull them down ) make SURE they are not blocked ( there is a rubber thing at the top that can close up--- just cut it open ) place a bucket under those pipes and leave your fridge off and the doors OPEN........ it may take a couple of days for ALL the ice to defrost. when you think its done--- leave it a few hours and if there is any water being collected --- you still have ice in there. i was amazed at how much and for how long water kept dripping out of the fridge drain pipe.... the pipe nearest to the compresser is for the frezzer, If the sensor that tells the fridge to get cold is all iced up it wont even try to get cold--- it thinks it is already.
Posted on Jan 03, 2009
SOURCE: Celestial split system air conditioner
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
Posted on Feb 10, 2009
woodchuck789
  • 4066 Answers
SOURCE: Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 08, 2009
SOURCE: Switch from Celsius to Fahrenheit Temperature setting
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
Posted on Mar 10, 2010
Pcm
Did you check the fuel pump relay ? The relay gets power from a fuse and also from the PCM relay. The computer grounds the relay to turn it on for 3 seconds when you turn the key on, then only after the computer "sees" RPM or oil pressure.
Feb 05, 2014 | 1997 Ford Explorer AWD
Engine runs rough if it warms up won't start dtc codes p0118 and p0113 just did head gasket and replaced exhaust manifold all new gaskets new plugs wires and coolant engine timing marks are all c
P0113 Intake Air Temperature Circuit High Input
Low temperature results in a high signal voltage. When the PCM sees a signal voltage higher than 5 volts, it sets this P0113 check engine light code.
P0118 - The engine coolant temperature (ECT) sensor is a thermistor screwed into a coolant passage in the cylinder head. Sensor resistance is high when coolant temperature is low and resistance drops when coolant temperature increases. The powertrain control module (PCM) provides a 5 volt reference and a ground to the sensor. The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
Potential Symptoms
Symptoms of a P0118 could include:
  • A no start condition
  • Vehicle may start, but run very poorly, blowing black smoke, running very rough and misfiring
  • Illumination of MIL
Causes
A code P0118 may mean that one or more of the following has happened:
  • A bad connection at the sensor
  • An open in the ground circuit between the ECT sensor and the PCM
  • A short in the voltage feed between the sensor and the PCM
  • A bad PCM (less likely)
  • A bad temperature sensor (shorted internally)
Jan 04, 2013 | 2003 Dodge Stratus
I took my vibe to the car wash about 40 feet out of the parking lot in started running on 3 cyl. and a light smoke coming from the exhaust i pulled off the road gave it a few good revs and she started...
The car wash pressure may have disconnected an electrical connector part way or completely. Check for this all around the engine and transmission. Touch and wiggle all of them! Dont forget to check under the car all the back to and around the gas tank. Also check for a vacuum line that is popped off or even broken.
Aside from that, water has got into something. Check all power distribution boxes for moisture.
If you dont know how old the plug wires are, or they are the originals, you should replace them.
With plug wires, its the age, not the miles.
Jul 31, 2011 | 2005 Pontiac Vibe
Mariner 2 hp outboard engine (1985) not pumping water
My Mariner 8 has a thermostat fitted. It only pumps water when it heats to normal temp.
If your engine stops, it may be a fuel problem. Check the plug and go to Marine Doctor (a) fuel diagnostics, (b) spark plug diagnostics, sections. PK
Jul 26, 2010 | Boating
Sluggish loss of power and popping noises from engine
Clean the distributer cap in the inside, it has water in it thus causing all the noises and the back fire.
Jun 20, 2009 | 1994 Volkswagen Golf
Engine light came on, temperature max heat.
It sounds like a plug got disconnected during the headlight change.
Feb 20, 2009 | 2003 Ford Focus
Shifting/tach
Is there a check engine light on at all?
Aug 16, 2008 | 1994 Honda Accord
1994 CHEVY CAVALIER V-6 STARTS TO OVERHEAT WHEN A/C RUNNING. ALREADY CHANGED THERMOSTAT AND ADDED COOLANT, STILL RUNS HOT, SOUNDS LIKE THE COOLING FANS AREN'T COMING ON WHEN THEY ARE SUPPOSE TO. CONSTANT...
Make sure you get the air out. There may be "high spots" on the engine that you can unscrew to let the air pockets t. Close this small valve when just hot water comes out.
Unplug the radiator fan and use jumper leads to test the fan operation. Use a scan tool to check for codes. If you get a scan tool that gives live data, see that the PCM sees the actual temperature of the engine after 5 to 10 minutes of running. It should see the temp. rising to 225 degrees farenheit.
Replace engine temperature sensor if the PCM doesn't recognize the proper temperature. You ARE going to compare this to the temperature gauge!!!
If all else fails, get the PCM recalibrated or flashed at the dealership.
Jul 16, 2008 | 1999 Chevrolet Cavalier
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
