Question about Vehicle Parts & Accessories
1994 chevy s-10 runns rough good full presser changed fuel componets in side pluntum spider and iac , cleand egr , poppets is there an order in the way thay plug in i put them in the way thay came out
Runs like garbage
    Sergeant:
  • 327 Answers
Check your spark plugs/ecm/plugs wires. You might also put a code reader to her. My 92 Sonoma will give codes even if engine light doesn't come on. Another issue you may be having is a clogged cat converter. It's like putting a potato in your tail pipe. Back pressure from exhaust builds up.
Posted on Mar 23, 2014
Testimonial: "the problem was on the spider some people call it was new and the check balls at the tips were not loose stuck from the coating that the factory put on them from rusting clean them up and turn the engine over till i seen gas spray out put it all back to gather and runs great now ! we will see how the cold start works in the mornning should ge about 10 tonight coold enough"
I have 1995 chevy lumina with the3100 engine. It starts fine but idle is rough and has loss of power and smells like unburnt gas.
How long since overall tune-up? Any applicable trouble codes?
The basics for a rough idle, check for a leak of some kind, fuel--egr--vacuum, something of that nature. Does it run ok off-idle?
Feb 16, 2017 | 1997 Chevrolet Lumina
Running bad
egr valve is stuck open,replace it and it will run.i dont know why they go bad when the spider does
Mar 23, 2014 | 1994 Chevrolet S-10
1994 chevy s10 blazer sputtering and dies
Check the IAC (Idle Air Control Valve) and the TPS (Throttle Position Sensor) they are a very common issue on that truck
Feb 25, 2013 | 1994 Chevrolet S-10 Blazer
4.3 94 chevy cranks sometime most time it wont change plugs , wire, dist,rotor button,crank module...getting good fire .. and fuel but still wont crank
check the fuel pressure to make sure it reads 55 psi when you turn the key on. if not the pump may be to weak to open the poppet valves on the injectors.
Jul 27, 2011 | 1994 Chevrolet S-10
I need to know how to look up the spider webbing, which is what everyone calls it but is not listed as that, in my 93 chevy s10 blazer 4x4 in the fuel injection, thx
some call the ''SPIDER' but what it is tube from the fuel meter body and it is under intake.it consist of fuel injector hold downplate,nuts,fuel injectors,poppet nozzles(tubes),fuel meter body,fuel pressure regulator,o-ring,filter screen.
Dec 13, 2010 | 1993 Chevrolet S-10 Blazer
No fire on passenger side new spider injectors new tuneup
I suspect that your CPFI unit has plugged injectors,the CPFI is Central Port Fuel Injection and is located inside the upper intake manifold,we call it a turantula because it looks like a spider,it houses the injectors or what is called poppets on this sys,they have problems with becoming plugged with carbon and causing a missfire,you can attempt to clean them but that usually does not work and is best to have it replaced,it is an expensive unit and GM has updated to a better system for replacment. I've also know of a few fire in the manifold that messed up the poppets.
Check the wireing harness to the injector first, may have gone lose, and try to get it scaned. Could be something simple.
Good luck and hope this helps.
Apr 03, 2009 | 1994 Chevrolet S-10 Blazer
Rough idling sluggish acceleration
These 4.3L W motors are common for fuel leaking inside the plenum causing them to run rough and smell like raw fuel. The fuel pressure regulator leaks internally, also the injector spider leaks and the two fuel lines feeding the fuel to the spider. You have to remove the plenum and look for the clean spot. Where the fuel leaks it cleans the oil off. Before you try this check your EGR valve. The EGR valves on these get stuck open with carbon and cause a rough idle. Remove it and look for the plunger it is a small round piece that you can push in and out, make sure it closes fully. You can also clean it with carb clean and they make a replacement gasket with a screen in it to keep chunks out of it. Start with the EGR because it is easier. The parts for under the plenum are available at most any parts store. If you have any problems just ask, and if you can not find the parts I will give you part numbers. Let me know what you find I will be back tomorrow.
Jan 07, 2009 | 1994 Chevrolet S-10 Blazer
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
