Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My system is too much slow how can i make it fast
    Sniper:
  • 58 Answers
This is quite a vague & general question, but some of the ways you can optimise performance of yor PC are:
  • Reduce the number of startup programs
  • Ensure your anti-virus is up to date
  • Remove some un-necessary files from your PC
  • Defragment your hard drive
1. There are so many programs which think you need to use them all the time, that they put themselves running when they start up.  Examples of these are Yahoo Messenger, MSN, Nokia PC Suite, etc, etc. Most of these will have an icon in the system tray (lower right beside the clock) You can right-click on these, and choose exit, but this is only temporary, they will re-appear when you next start up your PC.  To completly prevent them from starting up next time remove them from the startup folder on the start menu:
  • Click 'Start' -> 'All Programs' -> 'Startup'
  • If there are any items in here you don't need to be running all the time, right-click and select 'Delete' (This only removes the item from the startup menu)
You should also remove programs which have placed themselves into the registry to start up.
  • Click 'Start' -> 'Run' (Win+R)
  • In the Run dialog box, type 'MSCONFIG' and click 'OK'
  • In the 'System Configuration Utility' click the 'Startup' tab
  • This will list all the applications which run themselves at startup
  • Uncheck the boxes of the applications which you do not want to run at startup (remembaer you can always start them yourself anytime)
  • Some of these will be quite obvious as to what they are such as yahoo, googledesktop, winampa, but some may be not so obvious such as jusched, igfxtray.  Use a reliable site such as http://www.processlibrary.com/directory/files/igfxtray/ to identify what those processes are.
  • Once you're happy, click 'Apply' and then 'Close'
  • A dialog box will open asking to restart.  You can do this now or later.
  • When you do re-start, a dialog box will again pop-up notifying that you are using a selective startup.   You can dismiss this, and also tick the 'Do not show this message again'
  • If you find that something you were expecting isn't running, repeat the steps above, but tick the process to run at startup.
2. Ensure your anti-virus is up to date.  Most newer anti-virus softwares do this automatically, but you can force an update by right-clicking the icon in the system tray (lower right beside the clock) and chosing 'update'.  If you do not have a working anti-virus software, there are several high-end free ones out there such as Avast and AVG.
3. There are several 'stores' of information on your hard drive which are taking up a lot of meaningless space unless you keep on top of them.  These are items like the internet cache, the recycle bin contents, temporary files. These can all be cleaned in one fell swoop:
  • Open 'My Computer'
  • Right-click on your hard drive and select 'Properties'
  • Beside the pie-chart of the drive, is a button labeled 'Disk Cleanup', click this
  • Allow the Disk Cleanup wizard run, and select the items you want to delete from the list (You can select all if you like)
  • Click 'OK', confirm the next dialog by selecting 'Yes' and allow the utility to perform the actions selected.
There are also a number of temporary folders on the hard drive wich are normally quite safe to delete the contents of.
  • C:Documents and SettingsUser NameLocal SettingsTemp
  • C:WINDOWSTemp
4.  While all the other fixes so far have been quick to perform, defragmenting the hard drive may take some time depending on the size of the hard disk - hours, days, or in some cases, weeks. Over time, old files get deleted from the drive, and new ones are written, often over the data which was deleted, but the space for the file going in may not be large enough, so the drive puts some of the file in the space available, and the rest of the file elsewhere on the disk.  This is invisible to the user, but the drive knows where all the bits are, and puts all the bits back together when the file is opened.  Think of it as a large filing cabinet which is ordered alphabetically, where all new files going in are just placed at the back, when a file starting with say G is taken out, it gets put back behind all the other files following Z... Over time, the filing cabinet needs to be re-organised.  This is what defragmenting the drive is doing... taking all the files which have been broken up, and putting them all back together on the disk.  By having fragmented files, the hard drive takes longer to retrieve the files, often having to go back & forth across the drive instead of just reading the file in one go.  To defrag the drive:
  • Click 'Start' -> 'All Programs' -> 'Accessories' -> 'System Tools' -> 'Disk Defragmenter'
  • From the 'Disk Defragmenter' window, choose the drive you wish to check (usually c:) and click the 'Analyze' button, This will let you know if the drive should be defagmented or not.
  • You can click the 'View Report' button to see additional information such as free space, fragmentation details of files, etc.
  • Click the 'Defragment button to start the defragmentation process.
As stated earlier, this can take some time to complete.  Some steps you can take to speed up the process is to reduce usage of the drive while the defrag is running:
  • Disable your screensaver
  • Disconnect from the network, and temporarily disable your anti-virus
  • Ensure no programs are running
  • Disable the PC from going to sleep (especially on laptops)
  • Stop all applications in the system tray
By performing all these processes, you can potentially speed up your PC by up to 50% or more. (Depending on how frequently these steps are run... if ever!!!)
Hope this helps.
Posted on Jun 14, 2009
  • 52 Answers
Delete temporary files, cache and items on Recycle Bin. You may use Ccleaner to delete them safely in just one click. You may also run your computer without the unnecessary startup items. Click Start > Run > type msconfig. Select the Diagnostic Startup > Click Ok. Restart your computer
Techumseh 195cc lawnboy runs fast then slow then stops
Replace spark plug and air filter.
May 27, 2013 | Garden
Security sys light keeps flashing fast
your alarm system needs to be reset, it is indicating that the alarm had been set off by flashing fast...
Jan 15, 2013 | 2008 Chrysler Sebring Convertible
Atf6000fs2 does not fast spin to remove water only slow spin /checked it on all spin speeds
Either the motor cannot turn over fast enough to power the pulley system, or there is an issue with the pulley system.
Sep 04, 2012 | Frigidaire Affinity ATF6000F Front Load...
After installing the Symantec antivirus . My system become very slow. What is the reason?.
hi,
Symatech antivirus cpu usage is very high if your system is not a high configuration it makes slow.
the newer versions of nortorn antivirus are good and fast like nortorn antivirus 2010 so try latest version by removing old. or try avast anivirus which is very fast and working very good.
May 18, 2010 | Symantec Norton AntiVirus 2008: Windows
Zebra TLP 2844 prints slow in WinXP, but fast in
when submitting the print, un-tick the collate box. Use the properties section to check the speed settings in the driver and try again
Aug 13, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Very slow connection
there are various reasons why our connections speed slows down, it may be because of your system and it may also be of reading time.
a remedy for your modem may be to re-seat it to another pci slot and update its drivers.
hope this helps.
Jan 04, 2009 | U.S. Robotics 5699B (USR5699B) Modem
Problem in scanned images uploading
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers.
Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors.
If you had trace to that problem, then replace the whole unit of hub connectors.
Aug 08, 2008 | Microsoft Windows XP Professional With...
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Scanner doesn't scan
Start by changing the USB speed...
Two USB modes are available: Fast, which is the default, and Slow. Poor USB operation may be experienced in the Fast mode, in which case the Slow mode should be used to improve performance.
  1. Press the [Menu / Exit] button on the Control Panel. 'System Data' will be displayed on the Display Screen.
  2. Press the [Down] arrow button until 'System Setup' is selected, and then press the [Enter] button.
  3. Press the [Down] arrow button until 'USB mode' is selected, and then press the [Left] or [Right] arrow button to select either [Fast] or [Slow].
  4. Press the [Enter] button twice.
  5. Press the [Menu / Exit] button, and then press the [Stop] button to return to the Standby mode.
Jul 09, 2008 | Xerox WorkCentre M15ix All-In-One Laser...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
