Smeg wm63141 wont fill
MY SMEG IS FITTED WITH A PARTIAL AQUA STOP HOSE COULD i CHANGE IT FOR A NORMAL HOSE THANKS
4 Suggested Answers
  • 3 Answers
SOURCE: Dishwasher doesn't fill
try looking at the regultor it might be blocked theres a finn tube check it as it could be bunged up with muck
Posted on Mar 02, 2008
Master_Tech
  • 770 Answers
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
SOURCE: where is an Aqua-stop fitted in a dishwasher?
In the water inlet hose close to the valve on your supply end,its encased in a big ( 2") plastic housing with a brass fitting.
Hope this helps.
Posted on May 21, 2010
AEG Favorit 44080i Dishwasher will not fill with water
Well, this was very long-winded. If it works when filled manually, then check the stopcock for the water flow and open it more if not all the way. If this does not work, try the water pump in the back/bottom of the disher
Nov 07, 2014 | Dishwashers
Can i remove the aqua solinoid cut off valve from bosch dishwasher
the valve and wiring can be replaced you cannot remove it altogether as it wont be able to fill up, bosch aqua stops are normally powered solenoids that also double as the water inlet valve unlike most other aqua stops
Sep 27, 2014 | Bosch Dishwashers
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
Dishwasher cavitates. I have a Smeg DI612CA9
Does the drain hose loop up to the top of the unit before going to the sink drain? If it goes down first it may be siphoning or draining by gravity.
Aug 08, 2013 | Smeg Dishwashers
My washing machine water overflows tub it wont stop filling up, i changed the water inlet valve
Sounds like a sticking water level switch.
Locate thin plastic or rubber hose going from the bottom of the washer to the water leel switch at the top, remove and clean hose and the chamber at the bottom where the hose fits.
Nov 11, 2010 | Whirlpool Washing Machines
Where is an Aqua-stop fitted in a dishwasher?
Hope this helps.
May 21, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
The water continue to run for a long time
You are probably going to have to replace the fill valve.
There is a chance that adjusting it may work, but it has most likely become worn and partially clogged with hard watrer deposits, dirt, etc.
This will cause it to fill slower, and cause the fill level valve to close slower resulting in higher water level. Eventually it would simply overflow the flush valve tube.
Try adjusting the fill level, but plan on the likelyhood of replacing the fill valve.
Jan 21, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Smeg dishwasher
my hotpoint dish washer aquarius is 4 years old leaves a sandy grit all over dishes water not spraying the top,done all the usual stuff run out of ideas
Mar 09, 2008 | Dishwashers
Smeg DI 612CA
Take a look at this link http://www.smeg-service.co.uk/support/index.php?a=1&cat=4
Would seem to be the anti flooding device on the inlet hose
Nov 19, 2007 | Smeg 24 in. STX2 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
