Question about Nordic Track NordicTrack T6.3 Treadmill
Lights comes on but will not operate
Does it need the safety key to operate
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
Yes it need the safety key to operate
Posted on Mar 27, 2014
Why wont my car start gauges and lights come on but wont crank no power going to soelinoid wire
If the security system has been reset ( no light on/flashing ) you may have a neutral safety switch problem, Will the vehicle crank over in neutral? In most cases, the neutral switch grounds the starter relay and allows it to operate. Does the starter relay connector have 2 powers? One constant and one with key on/cranking? If these power supplies are there, suspect the ground side of the relay to be the problem and possible neutral safety switch
Jan 20, 2016 | 2000 Ford Taurus
I have a 2013 Yamaha venture re snowmobile is there a anti that device on this 2up
i don't know for sure but i think its more to do with safety rather than security , proberly part of the kill switch operation , contact a yamaha dealer for a more complete explanation
Feb 15, 2015 | Cars & Trucks
In my 2006 ford fusion 2.3L whenever I put my key in the ignition and turn it a weird solid ringing sound start and stops 5 seconds later hat could it be?
Not surprisingly, many others have experienced problems with the ignition switch on this car. Historically, it is not a sound, but that the key is stuck in the ignition. http://repairpal.com/key-will-not-come-out-of-ignition-570 Your problem sounds different, but it may be related. Although I do not recommend the fix in the link above, it is possible the previous owner of your car did perform this fix and it has resulted in the problem you now have. My better guess is that the chime/buzzer has failed due to moisture or dirt and is no longer producing the sound that it should, but instead is altered to the ringing you describe.To disable follow these instructions:
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
Step 3 must be completed within 50 seconds after the safety belt
3. For the seating position being disabled, at a moderate speed, buckle
then unbuckle the safety belt 9 times, ending in the unbuckled state.
(Step 3 must be completed within 50 seconds after the safety belt
warning light turns off.)
After Step 3, the safety belt warning light will be turned on for three
seconds.
4. Within 10 seconds of the light turning on, at a moderate speed, buckle
then unbuckle the safety belt.
This will disable the BeltMinder feature for that seating position if it
is currently enabled. As confirmation, the safety belt warning light will
flash 4 times per second for 3 seconds.
This will enable the BeltMinder feature for that seating position if it
is currently disabled. As confirmation, the safety belt warning light will
flash 4 times per second for 3 seconds, followed by 3 seconds with the
light off, then followed by the safety belt warning light flashing 4 times
per second for 3 seconds again.
I hope this helps. Good luck.
Jun 12, 2014 | 2006 Ford Fusion
Why won't incline go up or down?
Calibrating Your Incline Is your incline not operating correctly? There are a few simple steps that can be followed which will most likely resolve that problem for you.
9bvipvsqvatex9kgfcnn03s5zhvtng9too4023mrox7s22mjjuue73rxrrhupctrxro022nhu0i53bbtrxqocdrxro402hhw0410bbbtxqkad79poo41hbe1410ybbtwq+p8byj8qzuzzwaoaaaaasuvork5cyii=
The first step is to press and hold both the STOP and SPEED INCREASE buttons, this will be either an UP ARROW or a + (plus) symbol. While holding these two buttons down you will need to insert your safety key.
Once you have inserted the safety key you can release the buttons and let go of the key. At this point you will need to press the STOP button one time. Congratulations, you are now in Calibration Mode.
Now that we are in calibration, press the INCLINE UP button one time. This will cause the platform to go all the way up and then it will come all the way back down again.
Now that the incline has stopped moving you can remove the safety key.
Parts for ProForm Fitness Equipment Treadmills Bikes Ellipticals Belts...
Apr 26, 2014 | Proform Sport 1000 Folding Treadmill...
Do i need a safety key to start the tc1000
Yes, it will not operate without the yellow safety key inserted into the console.
Dec 15, 2012 | Bowflex TC1000 Treadclimber
When i go to start my 2004 Alero all the gauge lights come on but it won't start. The starter is still good. What could the problem be? Someone suggested that it was the neutral safety switch.
look for security light when you turn on key if it lights and doesn't go off leave key on for ten minutes then turn key off and then try to start
Oct 16, 2012 | 2003 Oldsmobile Alero
1996 dodge ram put the key in all the lights come on but it wont sart replaced the battery and the starter ssame thing
Need to check battery first . Does the car turn over and act like its going to start or not even turn over? Derek Carden
FixYa Support
Sep 27, 2011 | 1996 Dodge Ram 1500 Club Cab
On a 1998 oldsmobile cutlass,3.1 6cyl.auto...the shifter doesnt want to come out of park sometimes when the button is pushed..someone said theres a sensor of some sort keeping it from doin so,is this...
check to see if your brake lights are coming on. You need to have a good brake light fuse for the shift interlock to operate.
here are the things to check
brake lights on? no..then check
brake light fuse. ok? then check brake light switch OK? then check
neautral safety switch. OK then check lock solenoid.
try turning the key to the acc position then moving the shifter to neutral. start the car now.
http://wiki.answers.com/Q/How_do_you_get_the_gear_shift_on_a_1998_Olds'_Intrigue_to_move_or_unlock_when_it's_locked_in_park
Nov 12, 2010 | 2000 Oldsmobile Intrigue
My Uncle gave me a Horizon T605 treadmill and the
horizon rct 7.6 , safety key off , replaced ,key.reed switch and board , still says safety key off ?? spoke to horizon several times and repair techs as well ,it can only be 1 of those 3 items , all switch & key tested good , must be a faulty new board ?? could it be anything else ??
May 28, 2010 | Exercise & Fitness
I started mower in tall grass. It started up and immediately stopped. Could not get it started. Replaced battery. Charged 12 hours. Still will not operate. Green light is on. Noticed the blade seems to...
After charging the mower, you must place the safety key in the mower before it will start. On models that have a bail handle, be sure to pull the bail handle back to the mower handle before engaging the start lever. If your mower still does not start, remove the safety key and ensure the bail and start lever are in the "off" position. Then firmly re-insert the safety key, pull the bail handle to the mower handle and engage the start lever.
Note - It is important that the bail and start lever are returned to the "off" position before inserting the safety key.
Give it try, if it still will not operate you may have to take it in for service.
Good luck, let me know.
Regards,
Jul 30, 2009 | Black & Decker 19" Electric Lawnhog...
Nordic Track NordicTrack T6.3 Treadmill Logo
125 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
