Question about Denon Audio Players & Recorders
Denon turntable service center philippines
DP-47F. the tonearm does not move automatically
5 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Denon DP-47F
You might have a bad cue motor/ass'y. Did you buy this new, or used? Are you the original owner? Did this just start happening? Have you done anything different (moved the unit, cleaned it, etc) to the unit?
If the cue ass'y is bad, then that would require professional servicing.
- TWEAK AV LAB
Posted on Nov 26, 2007
dunnbiker
  • 8546 Answers
SOURCE: How do you adjust the
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Apr 14, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a DENON DP-47F
At least 7 of them on eBay with cartridges. Search "DENON DP-47F headshell" and check 'inlcude description' box.
http://cgi.ebay.com/NEW-TURNTABLE-HEADSHELL-CARTRIDGE-DIAMOND-NEEDLE-/350438023145?pt=LH_DefaultDomain_0&hash=item5197bbdfe9
http://cgi.ebay.com/NEW-TURNTABLE-HEADSHELL-CARTRIDGE-DIAMOND-NEEDLE-/350438814767?pt=LH_DefaultDomain_0&hash=item5197c7f42f
Posted on Apr 26, 2011
  • 444 Answers
SOURCE: Denon DP- 60L Tonearm bearings are loose, How should I adjust them..?
They can not be adjusted, Turn table has obvisily been abuse,Just buy a different one, End don,t abuse it,
Posted on Nov 02, 2012
Is it hard to fix the dp 47f
If you're asking the question then you are a novice. So I would suggest you leave any repairs to someone with the skills and expertise.
This Denon is a bit of a collector's classic. If you don't know what you're doing then you risk the chance that you'll wreck the deck and ruin its value.
Aug 23, 2014 | Denon DP-47F Turntable
How do i find a turntable cartridge technics headshell SL-BD22
The SL-BD22 turntable's tonearm does not have a headshell. It takes a P-mount (otherwise known as a T4P) cartridge which plugs directly into the end of the arm.
May 21, 2014 | Denon DP-47F Turntable
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
Which thickness setting should I use when playing my 33 rpm records on my Denon DP 297 fully automatic turntable? 17 or 30?
hi,
There are only two types of records available like 17 and 30. the size 30 will be as same as the turn table plater's size. 17 will be in half sized of the 30.
OK
Oct 22, 2011 | Denon DP-47F Turntable
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Apr 14, 2011 | Denon DP-47F Turntable
Turntable speed erratic
It is likely that grease has hardened and as the gears rotate that grease is interfering with normal operation. Take the unit apart and have a look at the drive mechanism, if there is something in the gears you should be able to see it.
Jan 01, 2009 | Denon DP-47F Turntable
Denon DP-47F
- TWEAK AV LAB
Nov 25, 2007 | Denon DP-47F Turntable
32 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
