Question about Remington Titanium Microflex R-950 Electric Shaver
No charger need a way to charge it
  • Remington Master
  • 1,624 Answers
A replacement cord for model R-950 can be purchased from shaveroutlet.com at the link below
http://shaveroutlet.com/universal-shaver-cord-coiled-for-most-models-p-268.html
Posted on Mar 29, 2014
My phone wont charge i always have to put it in a different position too get it too charge wats wrong with it?
Hi, there are two things you will need to test for ,
The charger and the charging port.
The charger of the phone might not be contacting properly causes it to fail or loose contact, that might be the reason it needs to be position properly before it charges.
You can use another charger to see how firm it will on another phone, so that you can be able to know if you will need to replace the charger with another one.
The charger port is where you plug in the charger to the phone for the phone to be able to charge.
Sometimes if the charging port is weak,itmight not be able to hold the charger properly,it will be failing contact.
Also you can use another charger to test with your phone and see how firm it holds on the phone and if it will charge the phone without failing.
I guess when you test for the charger and the charging port, problem will be solved.
Feel free to pass your comment.
Thanks for using fixya....
Jan 11, 2011 | Sanyo Cell Phones
My phone won't charge
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
When I plug in the charger it wont charge Im not getting like unauthorized charger message it just wont charge
I advice you try get a similar charger to charge your phone, if the similar charges your phone, it means your charger is bad and will need to get another charger or the phone.
But if it did not charge and you still get the same message, it means the charging port on your phone is the problem, the charging port on your phone is bad and can not read the charger, so you will need to replace or change the charging port on your phone. Doing thi will solve the problem on your phone.
Take care.
Jul 19, 2010 | Motorola Mobility Hint QA30 Cell Phone
Charging no respance
Hi, problem can be solved. When charging a phone and it does not respond,it means that either the charger or the charging port where you fix your charger in is faulty.
First you can try and use another charger to check if phone will charge. If it charges, that means the charger needs to be replaced,but if not charging,charging port will need to be replaced .
Take care.
Jun 09, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Hi I have N95 and when i plug charger in it says not charging can anyone help
Please check the charger by plugin with some other nokia handset and check if the charger is working fine. If still it shpws not charging with other handset then change the charger as charger is not working
Jun 01, 2010 | Nokia N95 Cellular Phone
Trying to charge my sony ericsson k800 mobile and it won't charge. Cannot get 'optimised charging' to appear. Battery now completely flat
Hi, you will need to get another charger. Charger might be faulty and will need to be replaced.
If after replacing charger and still does not charge, then the charging port where you plug in the charger is damaged and needs to be replaced.
Take care.
May 20, 2010 | Cell Phones
Motorola L9 no cherging
I suggest you try to use another charger to use another charger to charge your phone, if it does not charge, it means the charging port is bad and will need to be replaced.
You can also use your charger to charge a similar phone to see if your charger is not the problem, if your charger charges the similar phone, it means the charging port of your phone is bad and will need to be replaced.
Replace the charging port and your phone will charge.
Take care.
Apr 23, 2010 | Motorola Mobility SLVR L7 Cellular Phone
The charger slot on the phone does not work when plugged in, think it needs a new port
Why don't you use the charger to charge a similar phone or use a similar charger aside yours to charge your phone to see if it is the charger or the charging port.
If your charger charges a similar phone as yours, it means the charging port of your phone is bad.
But if it does not, the charger is the problem.
If it is the charging port, all you need to do is to replace the charging port and your phone will charge.
Take care.
Apr 21, 2010 | Samsung Instinct Cell Phone
Why doesn't my htc phone charge while plug in?
First, you need to check to see if the problem is with the phone - the battery - or the charger.
If you have a car charger, try to charge the phone with it. If it works, you'll need to replace your home charger.
If the car charger doesn't charge the phone - you'll either need to replace the phones battery or your home charger. (Sometimes the battery will go bad if you use a car charger not made specifically for the phone.)
If you replace your battery and it still doesn't charge you'll need to replace your home charger.
If after you've replaced the battery and the home charger and it still doesn't charge - your problem is with the phone and it will either need to be replaced or repaired.
Apr 07, 2010 | HTC FUZE Smartphone
My razr does not charge
when your phone doesn't charge,three things might be the problem,namely;the charger,the charging port of the phone or the battery.to be sure its not your charger,try using the charger to charge another phone of its kind,if it charges another phone then you can be sure the charger is not the problem,but if it doesn't,it means the charger needs replacement.
you can insert the battery in another phone and charge to know if the battery is the problem,if it charges then you can conclude the fault is not from your battery and the charger but rather the charging port of your phone is bad,you'll need to take it to a qualified technician to help you fix it
Feb 28, 2010 | Motorola Mobility RAZR V3
Remington Titanium Microflex R-950 Electric Shaver Logo
42 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
