Question about PowerDrive 150 DC To AC Power Inverter
It stopped coming on. Is there a fuse I can replace?
It used to come on and off. I had to shake it where the plug is and it would go off when bumped too much. I thought maybe a fuse was going bad. Is there a fuse that can be replaced on this device?
  • 400 Answers
Just a thought... check in the plug to see if there is a fuse in there. The bezel surrounding the tip will unscrew if there is a fuse in it. If you have to bump or wiggle to get something to run, there is definitely a loose connection. It could also be the cigar lighter socket itself. Find your loose connection (if it is not the fuse) and you will find your problem. I hope this helps you.
Posted on Mar 23, 2014
Ford F250 4x4 vibrates when it hit's a bump and then doesn't quit until you come to a stop or hit another bump
Steering shake ? Begin with have the steering & suspension expertly inspected & vehicle road tested....
Jul 03, 2014 | 2004 Ford Excursion
1. my radio just stopped working, it used to go on and off depending on the dots in the road or a big bump but now there is nothing, the fuses are ok too. 2. the horn does not work at all, fuses are ok...
it sounds like the plug in the back of the radio has come loose. remove radio and check connection. as far as the horn PULL THE WIRE FROM THE HORN UNDER THE HOOD THEN RUN A TEST LEAD FROM THE + SIDE OF YOUR BATTERY TO THE HORN IF IT HONKS REPLACE THE HORN RELAY IF NOT REPLACE THE HORN. GOOD LUCK
Feb 15, 2011 | 2006 Ford F-150
Uncontrollable shimmy in frontend
Haha the death wobble replace the steering dampner or shock on the lower tortion bar of the suspension with an heavy duty upgraded one. Not a difficult repair check the tortion bar bushing for play. But the death wobble is caused by the steering shock. Seen it a lot fixes it every time. Hope the info helps rate it please.
Jul 11, 2009 | 1991 Jeep Cherokee Limited
Steering shakes violently when I hit a bump
I had the same problem and it was a small shock sitting horizontally called the steering stabalizer your something close to that. Eazy fix.
Jason
Jun 02, 2009 | 1996 Jeep Grand Cherokee
My 2003 Kia Sorento shakes in the rear after hitting a bump however when you come to a comple stop it stops shaking?
Have look at the tyre if you could see any bulges or have a look at the rim on the edge for any damage
Jan 11, 2009 | 2003 Kia Sorento
PowerDrive 150 DC To AC Power Inverter Logo
132 people viewed this question
Top PowerDrive Electronics - Others Experts
Are you a PowerDrive Electronics - Other Expert? Answer questions, earn points and help others
